R55 Kick-down? What is this?
Old Mar 1, 2009 | 05:42 PM
n733lk's Avatar
n733lk
The '09 Clubman Owners Manual references "Kick-Down on pg. 41. It states that this procedure will increase your performance.
What is this and how do you "depress the accelerator pedal beyond the full-throttle resistance point"?
Thanks.
Old Mar 1, 2009 | 05:45 PM
ScottRiqui's Avatar
ScottRiqui
Basically, all that means is that if you press the throttle down past a certain point (i.e. "floor it" or darn close), the computer will realize that you're wanting maximum acceleration and will tell the automatic transmission to "kick down" to a lower gear.
Old Mar 1, 2009 | 08:04 PM
n733lk's Avatar
n733lk
Thanks. I never realized this had a "technical" name.
They should have just said "Floor It".
Old Mar 1, 2009 | 08:09 PM
not-so-rednwhitecooper
The transmission kick-down used to actually be a linkage that was attached to the throttle and transmission and signaled demand and triggered a downshift.
They probably still use the name because flooring it does the same thing the kick-down linkage did, even though it is no way related anymore.
Ever research where the term "debugging" comes from?
Old Mar 1, 2009 | 08:11 PM
muladesigns1's Avatar
muladesigns1
Ever research where the term "debugging" comes from?[/quote]
Do tell!
Old Mar 1, 2009 | 08:15 PM
From Wiki...
The terms "bug" and "debugging" are both popularly attributed to Admiral Grace Hopper in the 1940s. While she was working on a Mark II Computer at Harvard University, her associates discovered a moth stuck in a relay and thereby impeding operation, whereupon she remarked that they were "debugging" the system.
Old Mar 1, 2009 | 08:22 PM
ScottRiqui's Avatar
ScottRiqui
Actually, "debugging" was used synonymously with "troubleshooting" before the Hopper incident (at least in aeronautics). In fact, the log entry that was made when Hopper's team discovered the dead moth said "first actual case of bug being found", implying that the term "bug" was already in use to describe computer problems, although in a figurative sense rather than a literal one.
Also, the heading in the photo is incorrect - the "Moth Incident" was in 1947, not 1945.
Old Mar 1, 2009 | 08:24 PM
muladesigns1
hmmm. interesting how some of the terms in our daily lives get started.
Golsco
Mar 4, 2007 05:08 PM
