R55 Lowered Clubman
Old Nov 21, 2008 | 07:47 AM
IzzyG's Avatar
IzzyG
Lowered Clubman
Anyone lowered their Clubman via springs only yet? If so, what brand of springs did you use, how low did you go and are there any issues as of yet?
Last I heard was there needed more testing on the Clubman if lowered-by-springs-only was used. Any updates? I don't feel like tossing over a grand just to get rid of wheel gap. And if I do end up spending more than a grand, I'd rather do it right.
Old Nov 21, 2008 | 05:34 PM
Dead Ringer's Avatar
Dead Ringer
well there a few different springs out there, but unless you are going to pay for someone to do it, the springs themselves are only about $250... I lowered mine with coilovers and they BLOW the stock suspension out of the water (I had the sport suspension).
Old Nov 21, 2008 | 10:45 PM
RaceFace's Avatar
RaceFace
Got any pics of it lowered? I'd love to see them!
Old Nov 21, 2008 | 10:54 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
If they're testing them it's probably just to see if the clubman needs a different rear spring rate to make up for the added weight and wheel base. You'll be fine using any R56 spring set up. Many clubman owners have been running various r56 spring sets.
Old Nov 22, 2008 | 05:39 AM
inimini2007's Avatar
inimini2007
Rally
Wow...that's nice...
Are you running an exhaust, CAI, or an ECU in your clubman?
Old Nov 22, 2008 | 07:56 AM
Rally@StanceDesign
No, no engine mods, yet. It's not an S so there really isn't much available still.
Old Nov 22, 2008 | 07:57 AM
IzzyG's Avatar
IzzyG
Rally, would I have to worry about bad struts after 30-40k miles if only lowering springs are used though? I know I CAN use the R56 kits but I don't want a premature strut failure. Spoke to a few places and all of them say that blown out struts because of lowered Mini at 40k is part of the joy of owning a Mini-er not for me. :P
Plus, cost to replace the worn out struts would equate to coilovers anyways.(struts + springs = coilover)-costwise
Old Nov 22, 2008 | 08:14 AM
Rally@StanceDesign
Although I can't attest to the mileage that they would blow-out at.....yes, lowering springs on stock struts can cause damage or premature failure. They are not meant to be driven at a lowered ride height. It's not something that is immediate obviously, but they do wear quicker.
That's why coilovers really aren't THAT expensive in the long run
Old Nov 22, 2008 | 11:47 PM
Beastmaster's Avatar
Beastmaster
Eibach makes some springs specifically designed for the Clubman - don't lower it dramatically but drop it about an inch and make a big difference to the handling. I have them on my Clubbie in the UK and I assume they can be sourced in th U.S.
View large on Black
Old Nov 23, 2008 | 06:11 AM
IzzyG's Avatar
IzzyG
Beastmaster- there's a few Clubman specific springs but they still tend to wear out your struts prematurely. I think I'll just have to save a tad longer to go the coilover route.
loop4re7
Oct 5, 2015 09:53 PM
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
Accessory Products
Aug 11, 2015 12:37 PM
