R52 Stuttering R52
Old Apr 10, 2022 | 09:29 AM
Bobbyg24's Avatar
Bobbyg24
Stuttering R52
Morning all!
I have a 2008 r52 S. Recently it has started to stutter, like it wasn't getting gas. This is an intermittent issue. Doesn't always happen.
What are some possible issues and what are the fixes?
My 1st guess is that the fuel pump is going bad, replacing is the fix. I would also replace the fuel filter at the same time.
Bad fuel filter?
Bad gas?
I am not so sure of the last two possible scenarios as I mentioned the stuttering is intermittent and comes at unpredictable times.
Thanks in advance for any comments and or solutions!
rob
Old Apr 13, 2022 | 06:11 AM
ChiefM's Avatar
ChiefM
Could be a MAP or TMAP going bad. From what I have seen many have had sucess with replacing the TMAP, only use a factory sensor. Aftermarket only cause more issues.
Old Apr 20, 2022 | 05:48 PM
gobeyrz's Avatar
gobeyrz
Mine just started stalling randomly coming to a stop at low speeds...in either 1st or 2nd with clutch engaged. Just losing RPMs. Might be a different issue than yours, if yours is stuttering at speed.
Old Apr 21, 2022 | 01:19 AM
ChiefM's Avatar
ChiefM
Mine used to do that and it was the fuel pump. Check your fuel pressure.
Old Apr 21, 2022 | 12:44 PM
gobeyrz's Avatar
gobeyrz
Thanks - yeah, I have a service appointment coming up anyway for some minor things (random seatbelt and airbag warnings) and adding this to the list. Does indeed look like a fuel pressure issue.
Old Apr 28, 2022 | 02:57 AM
dmath's Avatar
dmath
@Bobbyg24 Do you have access to a code scanner? Preferably one that reads BMW-specific codes. Knowing what, if any, codes are present usually helps.
Old May 5, 2022 | 11:43 AM
gobeyrz's Avatar
gobeyrz
So...fuel pressure was fine...my problem (stalling at low speeds) is clutch-related. I guess 151k miles on original clutch was pretty good!
Am going to probably sell it on CL "as is" with all major items addressed in services the last two years (everything except key fobs work fine)....just not worth it to put the quoted dollars into a new clutch for me given I just drive it for fun around town.
Old May 15, 2022 | 07:17 AM
Bobbyg24's Avatar
Bobbyg24
Thank you for the input! Greatly appreciated!
bikemessenger
Apr 24, 2019 03:24 AM
Manny_cooper
Oct 23, 2016 04:25 PM
Wertles
Mar 18, 2016 10:58 AM
bc219
Aug 10, 2015 11:22 AM
wildfamily
Mar 10, 2010 07:31 AM
