R52 R52s Cranks but No Spark
Old Dec 11, 2018 | 09:26 PM
Ronald Menendez's Avatar
Ronald Menendez
2007 MINI Cooper S
Hello Everyone My Mini has no Spark on all 4 Spark Plugs I Connected my Power Probe and have 12V+ on all 3 cables that Connect to the Ignition Coil Plug.
I did some Research and the 2 Black Wires are supposed to be Grounds and the Red Wire goes to Fuse #2 on the Fuse Box that is on the Engine Compartment next to the ECU.
Does anyone Know what my Issue may be? Thanks in Advance
Old Dec 12, 2018 | 04:47 AM
Tgriffithjr's Avatar
Tgriffithjr
Is the fuse good? Assume the coil connection is clean? Any codes? Assume also it cranks but no spark?
Old Dec 12, 2018 | 05:43 AM
Ronald Menendez
It’s giving me a EWS Wrong Code when I Hook up the OBD2 Scanner
Old Dec 12, 2018 | 02:39 PM
Tgriffithjr
[QUOTE=Ronald Menendez;4437084]
It’s giving me a EWS Wrong Code when I Hook up the OBD2 Scanner.[
/QUOTE]
I believe that means your key is not synced with the DME so it won’t start. I could be wrong though.
Old Dec 12, 2018 | 03:02 PM
A383Wing's Avatar
A383Wing
Yes, it sounds like the EWS module has gone out of sync..... I had the same thing happen on my '06 R52 JCW car earlier this year, had to send it out to RPM Motorsports for repair. I had no spark and no injector pulse when cranking it over
Bryan
Old Dec 12, 2018 | 03:15 PM
Tgriffithjr
I believe I’ve read that you can perform the sync if you have the right software like INPA.
Old Dec 20, 2018 | 02:50 PM
A383Wing's Avatar
A383Wing
yes, that is correct, but I didn't have the software or access to it......I sent mine to RPM Motorsports
Bryan
Old Dec 30, 2018 | 10:25 AM
Tgriffithjr
Did you ever get this resolved?
Old Dec 30, 2018 | 12:04 PM
A383Wing's Avatar
A383Wing
He was last on this site 12-12.....when he posted this.....hasn't been on since
Bryan
thewizz
Nov 2, 2016 09:10 AM
ctrlaltdl
Jan 14, 2016 07:48 AM
wiredracer
May 5, 2014 09:04 AM
DMAC57
70
Sep 11, 2008 08:20 PM
