R52 Mini Cooper r52 convertible top is not completely open
Old Dec 22, 2014 | 12:55 AM
slide mini's Avatar
slide mini
Mini Cooper r52 convertible top is not completely open - YouTube
"> Mini Cooper r52 convertible top is not completely open - YouTube
" type="application/x-shockwave-flash" width="425" height="350">
this is a my first post in this nice forums
Hello every body
and i hope to get help
Just I replaced the cables latch & front lock with OEM new parts
Then when I finished I try to open it
The sun roof opening fine but when I tried to open top with the second press on push switch
The another close switch blanking with red light
Locks not working full closed & open
Top not open
check above video pls
Any help comments pls ?
Old Dec 22, 2014 | 02:24 AM
rkw's Avatar
rkw
Is the rear shelf completely down in the luggage compartement?
https://www.northamericanmotoring.co...on-t-open.html
Old Dec 22, 2014 | 05:48 AM
slide mini's Avatar
slide mini
Thank you very much
I do same as you said
Now the lock completely open with windows but after the switch now blinking red after lock open and top not open
Old Dec 22, 2014 | 06:04 AM
slide mini's Avatar
slide mini
Thank you friend
Now it's working fine after I make adjust for lock sensor
Old Dec 22, 2014 | 06:12 AM
Here are some links to how the top functions.
https://www.northamericanmotoring.co...t-closing.html
https://www.northamericanmotoring.co...tible-top.html
Make sure both latches unlock. There is a green hall sensor that detects when the top is back. Also I would make sure the pump has power , when the top makes that second phase , the cables goes back a little more then then the latches open up.
Your latches should not open till it gets to that second phase. When you push the button the second time, something is not right. See the operation in the linked videos.
Thanks and good luck.
Old Dec 24, 2014 | 03:24 AM
Deluded's Avatar
Deluded
Originally Posted by slide mini
Thank you friend
What did you do? What lock sensor? My car has the same problem, please advise.
Old Dec 24, 2014 | 04:01 AM
slide mini's Avatar
slide mini
Hello dear
First thing check the shilf in trank back side if it's correct in position
If its ok try to make adjust for lock sensor - that is location on top of the sunroof motor
Try to move it little right or left
Then check
Good luck
Old Dec 25, 2014 | 11:56 PM
Deluded's Avatar
Deluded
Did you remove the sunroof motor? Or did you adjust it with the top open, or....?
There is no documentation about the lock sensor in alldata, BMW TIS or anything.
Can you please clarify? Thank you.
Old Dec 26, 2014 | 02:47 AM
slide mini's Avatar
slide mini
I just remove the top cover
There's one sensor on top the sun roof motor , on cable way
Open the scrow and move it liitle right or left and check
The lock it will be change when you close and open sun roof
Old Dec 26, 2014 | 10:06 AM
Deluded's Avatar
Deluded
Thank you, I will check tonight.
This is making me excited...My top has been inop for about a year and half. Sunroof works, convertible top works, but it just refuses to open after the latches unlock. Once I "push" the top by 1", the convertible top kicks in and it retracts.
Old Dec 29, 2014 | 12:45 PM
I believe you are talking about the upper microswitch. At the end of #1 . Up by the motor in the overhead fro the sunroof portion.
Top Tensioner Switch 61316967660
http://www.ecstuning.com/Search/SiteSearch/61316967660/
Old Jan 1, 2015 | 10:19 AM
slide mini's Avatar
slide mini
Yes that's is
There's adjust for this switch
Yes that's is
When make adjust for this switch
The lock will change for more locking or lose lock
Old Jan 5, 2015 | 02:44 PM
iggi
18
Feb 9, 2026 01:00 AM
andrewjg1994
Jan 29, 2021 07:45 PM
mrjolliff
Oct 9, 2015 05:55 AM
joelcseymour
Aug 7, 2015 12:43 PM
