R52 *HELP*2005 R52 Rear Parking Sensors Not Working
Just got my Mini R52 from the dealer yesterday, 8/14/12, to do an oil change, replace an O2 sensor, and replace a seized power steering fan. Now from the information that I found on this great forum, I know that the power steering fan and the rear parking sensors are on the same fuse. When I got home I changed the blown fuse,5A, don't know why the dealer didn't change it, and tried backing up to a wall. The parking sensors were not working at all. Before I call the dealer, any ideas or suggestions on what the problem could be? Thank you All in advance.
Do the back up lights work? Park assist only works when reverse is selected as do backup lights. That would be a clue.
I agree, fuse should have been replaced. I guess they didn't test the fan after replacement.
I love it, they charged me an arm and a leg to install a new fan and didn't even check to see if it works. Put a call into the dealer and waiting to hear back.
Seriously? Park assist is that great? I've never crunched a bumper. Actually only on my first car (parents mini van), cus there was a concrete flower planter that was 2 feet high. I was mad... maybe park assist would have helped. But it my older days I'm always more aware. back then I'd throw it in reverse and floor it, slam the brake and put it in D while I was still sliding backward, and then floor it again - Park assist, ABS, CEL none of those driving aids were of any use to me back then, only driving aid that worked was my dad in the passenger seat lol.
But these day's i don't think I would ever need park assist, especially in an R50. DSC has made me lazy and less of a man, ABS might be a necessity.
Check the fuse for the rear sensor and power steering fan. That could be your problem.
The power steering pump fan and backup sensor share the same fuse...
So i bet grit and sand got into the bearings in the ps pump fan, jammed it, and blew the fuse. Post 2005 production cars are wired this way, so ALL R52'S ans some r50/53's do.
Edit..read the op...amazing the person replacing the fan did not do the fuse too!!
Some Tips from mini2 forum
Mine had a blown fuse and thus a simple fix so far. I saw these comments on mini2/forum that were helpful:
- Backup sensor and the reverse lights function with the ignition on but the engine stopped: thus easy to test by walking behind the parked car while off rather than backing to a wall.
- Silence could be issue with speaker which is buried behind back seats.
- If there is constant beep for 10 sec when put in reverse, then this indicates a fault; To ID faulty sensor: go to the rear sensors, bend down and put your ear to the sensors, you will hear a clicking sound, this means that there is power down to the sensor, the one that does not make the clicking sound is at fault; check your connections in the back of the sensor, if ok, 9 times out of 10 its the sensor thats at fault!
xraycat
Aug 12, 2015 02:36 PM
DWooderson
Aug 10, 2015 09:12 AM
