R50/53 little problem
Old Jan 27, 2007 | 10:23 AM
HighSchoolzMINI's Avatar
HighSchoolzMINI
little problem
I just got my engine damper from Shoe (thanx man)
and I need to install it
I wanna do it but not alone
I live in Jackson Heights Queens, any fellow NAMers wanna help me out?
It would be greatly appreciated!
thanx
Matt
Old Jan 27, 2007 | 12:50 PM
kenchan's Avatar
kenchan
let your gf hang out then...
Old Jan 27, 2007 | 02:33 PM
HighSchoolzMINI
she cant stand it
and i need somebody that knows what theyre doin :lo:
Old Jan 27, 2007 | 03:40 PM
kenchan's Avatar
kenchan
i see.
Old Jan 27, 2007 | 03:43 PM
Motor On's Avatar
Motor On
Take the computer out tot the garage, boot up NAM
Old Jan 27, 2007 | 03:54 PM
jeffc's Avatar
jeffc
7th Gear
Yeah thats all the help you need
Old Jan 27, 2007 | 04:00 PM
HighSchoolzMINI
i cant get my ethernet to reach outside, but my computer wont load the instructions for later model years, and i drive an 06 MCS so it wouldnt help anyway
Old Jan 27, 2007 | 04:10 PM
erickvonzipper's Avatar
erickvonzipper
I'm in Massapequa. You got access to a lift and air tools? I'll come over and help with yours if I can get my new exhaust system in, as well. Otherwise, I gotta struggle with it on jackstands here.
Zip
Old Jan 27, 2007 | 04:12 PM
kenchan's Avatar
kenchan
lol! a lift and airtools for installing shoe's damper?
Old Jan 27, 2007 | 04:14 PM
Motor On's Avatar
Motor On
But someone did miss the hey come gimme a hand with my exhaust and I'll help you with your damper bargin.
Old Jan 27, 2007 | 05:43 PM
erickvonzipper
Uh, yah, that was the general idea.
Zip
Old Jan 27, 2007 | 07:13 PM
HighSchoolzMINI
lol sry man, im a broke high school student, if i had a lift id be in heaven, but its okay anyway, im goin to see shoe in Tarrytown tomorrow morning, so its all good
thanx everybody
Old Jan 27, 2007 | 07:29 PM
MOE4me's Avatar
MOE4me
I've been reading these damper threads the last couple of days, trying to figure out exactly where the difficulty lies in this mod. Basically threading one bolt into an existing threaded hole in the block and getting a nut on another bolt.
Unless, of course, it's that whole removing the dip-stick for more access room part
Old Jan 27, 2007 | 07:50 PM
kenchan's Avatar
kenchan
Zip
that actually sounds like a smart plan.
damper install difficulty: 1 (out of 10 as hardest)
exhaust install difficulty: 2
still dont need air tools to do exhaust install.
Old Jan 27, 2007 | 07:51 PM
kenchan's Avatar
kenchan
thanx everybody
cool, yah, i thought shoe was in NY area. so that's a great deal.
let the engine damper master do his magic.
Old Jan 27, 2007 | 08:06 PM
Motor On's Avatar
Motor On
+1 But I suppose they might make things easier you know drop the amount of time spent on it. But thats about it.
Old Jan 28, 2007 | 06:57 AM
erickvonzipper
Okay Mr. 15k+ posts-Smart-Guy , how do I loosen up those rusted-almost-solid nuts/bolts that keep the front and rear togther when I can barely fit under there, I've sprayed WD40 on them several times, and they won't budge with hand tools? Hmm? HMMMM?
Zip
Old Jan 28, 2007 | 11:02 AM
MOE4me's Avatar
MOE4me
Breaker bar and a 2' length of pipe...something's bound to break free.
Air tools do tend to make most jobs easier (if you have access to them), if not, there's always more than one way to bust a nut...so to speak
Old Jan 28, 2007 | 11:37 AM
erickvonzipper
That's a great idea, but as I had stated earlier, I barely have enough room under there for myself, never mind a 2' beaker bar. But thanks. =o)
Zip
Old Jan 28, 2007 | 12:08 PM
HighSchoolzMINI
well u can come by and use my ramps, they give you like 12-18 inches of clearance
Old Jan 28, 2007 | 02:35 PM
erickvonzipper
Also a good suggeston. Thank you for the offer.
I have two sets of ramps. One, the taller set, doesn't reach the tire because it hits the lowest part of the bumper when you try to shove it under there, and the other, which is lower, scratched up the plastic at the bottom when I tried to drive the car up to change the oil a few weeks ago. Neither set will fit under the side of the car so that I could drive all 4 wheels up two sets of ramps so I could really get under there.
I finally bought one of those 3-ton hydraulic floor jacks to make easier to get the car up enough to swing a wrench on the oil drain plug.
I need a lift, and a torch, neither of which I have.
Zip
Old Jan 28, 2007 | 02:46 PM
BigBrownDog's Avatar
BigBrownDog
+1 on the breaker bar - I've done this mod twice on two different MCS'es - both times those front bolts were rusted on tight. The breaker bar gave me just enough leverage to pop them loose. Mine was about 18" long -- I didn't need any additional pipe for leverage, also since the car was on jackstands there wasn't much room anyway.
Old Jan 30, 2007 | 07:29 AM
LordOfTheFlies's Avatar
LordOfTheFlies
Sorry I missed this earlier Matt....But glad you got in touch with me. If anybody in the NY area needs help, drop me an e-mail or pm and we can set up a time.
Old Jan 30, 2007 | 07:51 AM
kenchan's Avatar
kenchan
Zip
hey zip- i use what i call a shorter 3/8 drive breaker bar.
you can also use a wrench and a mallet to tap it free.
Old Jan 30, 2007 | 10:28 AM
HighSchoolzMINI
its all good, im just happy i got it done
