R50/53 Steering wheel shake
Our '03 MCS has a shimmy/shake in the steering wheel from around 20mph to 50mph. the shake varies in intensity, never is it real bad, but it is definitely there. I had new tires put on, balanced and aligned. While this reduced the issue it did not eliminate it. My theory is a rim may be warped or out of whack. If it's not that, what else could it be. Any ideas?
Check this thread...
https://www.northamericanmotoring.co...ad.php?t=73735
it might be what your car is doing.
best would be to swap the wheels/tires with your spare if you have
a set and compare.
otherwise, i would put the front ones on the rear and see if that
helps. if yes, your front needs to be rebalanced.
a set and compare.
My vote is bad wheel hub on front drivers side. Second vote bad hub on passenger side. Was probably okay until you took weight of car off the hub to change tire/wheels. ie failed like a water pump after belt tension is removed... you get the idea... Can probably make the symptoms go away for a while but ultimately there is a bad part in the front end, hub, tie rod etc. Especially if more than 50k miles on the car.
Manny_cooper
Sep 10, 2015 11:09 AM
trw92a
Aug 26, 2015 01:47 PM
Navigation & Audio Steering wheel controls for music
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
