R50/53 Is it easy to replace manual shift knob?
Old Sep 3, 2006 | 11:17 AM
srfrman7's Avatar
srfrman7
Is it easy to replace manual shift ****?
Hi,
I might be purchasing a used mini cooper and was wondering if it's easy to replace the stock manual shifting know. The one that is on there has some scratches on it.
If it's easy, how much does a new factory standard **** cost? Just the **** itself... not the boot. Also is it easy to replace? Thank you!
Old Sep 3, 2006 | 11:25 AM
skitelluride531's Avatar
skitelluride531
Yes, it just pulls straight up, and off. Just needs a little tug.
Maybe you should consider getting a whalen shifter: www.whalenshiftmachine.com
Old Sep 3, 2006 | 11:37 AM
ARTSJCW's Avatar
ARTSJCW
Make sure you look at Whalen. Doug is a great guy and also does many custom shifters
Old Sep 3, 2006 | 11:53 AM
buzzs06s's Avatar
buzzs06s
Push down and pull strait up, FIRM AND HARD!! one firm tug should do it
Old Sep 3, 2006 | 12:10 PM
BFG9000's Avatar
BFG9000
If you straddle the lever try not to smack yourself in the nuts when it lets go. And whatever you do don't use a claw hammer like MINIotaple did.
Originally Posted by MINIotaple
Remove the ball from the shifter. I was expecting this to be hard since everybody had mentioned it. But let me tell you, no amount of reading or preparing helped. It took forever. I finally get the genius idea to clamp the wrench onto the shift lever and use the clawside of the hammer to pry the ball off. I try this a couple of times and finally all hell breaks loose and I lose hold of the hammer and it's flying and monkeys are flying out of the transmission's rear. In the aftermath, I get a chance to look. The socket is off. Hooray. Then I look to the right and laying right next to my head is the claw-side of the hammer... :impatient One inch and I could've been eyeless of even lifeless.
Old Sep 4, 2006 | 08:49 AM
JCW210's Avatar
JCW210
Best way is to sit in the rear seat...car in reverse gear and pull like mad ,watch out for black eyes and other sore bits !!!
Old Sep 4, 2006 | 09:43 AM
kenchan's Avatar
kenchan
Originally Posted by srfrman7
Hi,
sit over your brake lever (not on it you fool ) take both hands on
the ****, put your wrist over your knees and use your heels to push up.
it takes some force, but it will come off.
if you just pull it up, you'll end up hitting your forehead with it.
Old Sep 4, 2006 | 09:58 AM
Jayde's Avatar
Jayde
If the car has a sunroof, make sure its open!!
Old Sep 4, 2006 | 10:17 AM
El_Jefe's Avatar
El_Jefe
I smacking the crap out of my test car's shifter and it flew off into the rear seat. that little stick was hard to move right without the ****.
Old Sep 4, 2006 | 10:19 AM
thefuturequeenofnebraska's Avatar
Be careful!
(and check out Whalen *****! They come on and off easily too!)
Old Sep 4, 2006 | 10:23 AM
HighSchoolzMINI's Avatar
HighSchoolzMINI
What if hes getting the MCS then he cant put it in reverse, but in sixth gear
HighSchoolzMINI
and I just realized that he said he was getting a cooper
Old Sep 4, 2006 | 11:18 AM
creseida's Avatar
creseida
I just put my driver's seat all the way back, put the car in 2nd gear and pulled. Came off without much difficulty.
The boot is easy to replace too.
Old Sep 4, 2006 | 11:22 AM
Android993's Avatar
Android993
I have one on ebay right now. cheap so far. Stock ****.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
also my Alta 0% crank pulley.
Old Sep 4, 2006 | 12:32 PM
Motor On's Avatar
Motor On
I just pull up no extra tricks here. A factory **** off ebay, will be the most cost effective method. Or call Classic MINI for a discount off of the $50 MSRP. Or you can go Whalen (highly reccomended by many many MINI owners) Also MOMO and JCW have options to fit a MINI.
dyeLucky
Sep 11, 2015 10:41 AM
Mini-Hype
Aug 17, 2015 06:32 AM
Powershift
Aug 16, 2015 05:14 PM
dyeLucky
Aug 7, 2015 07:10 AM
