R50/53 Burnt smell??? Clutch
Old Jul 7, 2006 | 08:09 PM
Mini C's Avatar
Mini C
I am in Seattle..which has some very steep hills. Today I was at a hill and I start to smell a burnt smell and I saw smoke coming from the engine. The temp gauge was fine but now whenever I hit the clutch for more than a few minutes I smell burnt rubber. Did I burn out my clutch??? The car runs fine....does anyone know if the BMW dealership in Seattle services mini's?
Thanks for any responses.....
Old Jul 7, 2006 | 08:13 PM
Gromit801's Avatar
Gromit801
Well for a start, NEVER keep the clutch depressed. Like at stops signs or lights. You WILL shorten the life of the throwout bearing in the clutch assembly. Always pop your tranny into neutral at stops.
Are you sure that you're not smelling burnt brakes?
Old Jul 7, 2006 | 08:16 PM
Mini C's Avatar
Mini C
I am sure it's the clutch....cause anytime I hold it down for more than a few minutes it stinks. The car only has 21 miles on it.....
Old Jul 7, 2006 | 08:20 PM
Gromit801's Avatar
Gromit801
Ok. Take it to the dealer and ask what's up. But remember not to keep the clutch pedal depressed except to shift. There's no reason to hold the clutch down for more then about 2 or 3 seconds.
Old Jul 7, 2006 | 08:24 PM
Mini C's Avatar
Mini C
Thanks for the info...I just hope the local BMW dealership works on mini's or this one is going to end up in puget sound......
Old Jul 7, 2006 | 08:37 PM
Gromit801's Avatar
Gromit801
There's a slim possibility that some kind of preservative coating is being burned off. Something usually removed before installation.
Old Jul 7, 2006 | 08:53 PM
Yucca Patrol's Avatar
Yucca Patrol
If the car only has 21 miles on it, you must be pretty close to a MINI dealership. . . .But it definitely sounds like the clutch is wonky.
Old Jul 8, 2006 | 07:57 PM
Checkmate's Avatar
Checkmate
It sounds like what I did to my clutch. I was told that it needs to be all the way in or all the way out, no leaving it partially catching. I noticed mine do that just after a few hundred miles. I think you'll be ok but take the advice of putting it in nuetral at stops and hold the clutch in as little as possible.
drrigg
May 27, 2022 03:31 AM
mni928
Nov 9, 2015 07:38 PM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Sep 28, 2015 09:13 AM
