R50/53 What happens to an "S" when the supercharger is disconnected?
OK...besides the obvious...less power...are there any reasons an "S" can not have it's supercharger disconnected?
Let me explain:
I'm in the market for an MC...but in the used marketplace, it seems like 90% are MCS's.
Part of the reason I want an MC instead of an MCS, is the fuel economy...plus, somehow an MC seems more "pure", and it's still a LOT of fun to drive, even with so much less power than the MCS.
So...
I'm wondering if I bought an MCS, then disconnected the supercharger, would it be driveable? Would the computer operate the car OK, etc? Are there any mechanical or technical reasons why the supercharger could not be disconnected?
I know...strange topic.
Let me explain:
So...
Well, like I said, fuel economy, "pure-ism" (OK, that's not that important), and sheer availability...if I want, say, this color and that combo of packages, etc, there's a LOT more choice in MCS's than MC's.
I've got a nice 2003 Cooper I'll sell you.https://www.northamericanmotoring.co...ad.php?t=61768
Well, lets see....
The Cooper has about 115HP - the S has about 168HP ( stock ). Without the SC the S would have ALOT less HP than an MC. Let me explain....The SC is a air pump that is INLINE - it can not be bypassed by simply taking the belt or pully off - if the SC is not turning then there is very little air getting by it - therefore a HUGE restriction in the intake. Also the stock compression ratio of a MC is about 10.? : 1 and the comp. ratio of a S is about 8.? : 1 -- so with out a SC the S motor will make LESS HP than a stock MC even under ideal conditions. Will the electronics run a non-SC engine -- maybe, but it will not run well.
The cure is to remove the SC and all related intake parts ( intercooler, etc ) and install orig. MC intake parts. Then either have the computer flashed to a std. MC program or replace the computer with a MC computer.
Will all this work? I have no idea:impatient It seems like alot of work to detune a S so you can have a "pure" MC.
If you can get a S cheaper than a MC, then I say buy the S and have some fun with it - they are a blast to drive
Oh, by the way - I didn't even get into the Tranaxle - I don't know how a detuned S would handle everyday driving with the stock S transaxle???
Brilliant! A thread where an MCS owner is trying to build their car into a Cooper instead of the other way around (for once).
This makes me happy...
If you want better mileage, the easy things are to make sure you have enough air in the tires, and shift at lower RPMs.
The supercharger bypass valve is included as a means to approximate disconnecting the blower at part throttle. Some of the mechanical drag remains, but the pumping losses are minimized somewhat. The remaining drag, along with the lower compression ratio are the primary factors in the MCS economy being less than a MC.
Take the spring out of the by-pass valve...
But it would suck to drive, for all the reasons listed above. Or use the set-screw to keep it from closing all the way, to limit boost. But that's going backwards.......
Matt
Matt
So...
This is really a non-starter (probably literally). Just shop till you find an MC that you like.
Originally Posted by cct1
Removing the supercharger from an "S" is like ordering a cheeseburger without the cheese....
Thank goodness....
Why buy a used MC when U can configure a new one the way you want it, pay not much more, and have the full warranty and mtce.? Plus, the 05s on are much better cars with the Getrag 5 speed as opposed to the generally clunky Midland tranny, and U could do a JCW lite to give it more oomph. Maybe snag a dealer demo?
Last year after Katrina used Coopers of all kinds were hard to get; who knows what will happen here if gas averages over $3/gal. I say go new! (if U can.)
Jimbo
Originally Posted by sequence
Thank goodness....
Jimbo
Thanks...
Any other improvements in the '05's and higher?
Many... compared to the '02-'03 cars.
Better seat mecahnisms
More interior storage
Less prone to rattles
Better suspension adjustment capabilities
Better door hinges (the old ones rust, fast...)
I'm sure there's more.
yea, you cant just remove the belt from the supercharder, the tensioner doesnt work that way. but...you COULD make a LARGER SC pulley. I just kidding with this, but if you had , say , a 50% increase pulley. you would, of course be running only 5psi as opposed to 10.5. that would reduce the SC effect...lol
You can't just disconnect the S in MCS. It is part of a designed system with other internals dependant upon it working.
What you can do is buy an S and drive it easy... you will get good mileage... yet when you need the extra power... it will be there...
It's always better to have some power on tap for when you need it..
You have to use premium anyway... might as well get something for it...
