R50/53 MINI Oil Change...
Old Jun 30, 2006 | 12:22 PM
BriNYU's Avatar
BriNYU
MINI Oil Change...
Hi Everyone! So I just got off the phone with Patrick MINI re: 40k Oil Service. I tried to get my oil change done while my warranty was still vaild a few thousand miles ago, but they wouldnt do it. In any case, it costs $180 for an oil change.
So here's my question. If I picked up an OEM filter, are places like Jiffy Lube, etc viable options? I've heard bad things. As much as I'd like to do it myself, I just dont have the time and, well, I'm lazy.
If anyone has any input/experience with this, I'd really appreciate it. I'd bring my own oil (would like to try out Mobil 1's Extended Performance.
Old Jun 30, 2006 | 12:37 PM
davisflyer's Avatar
davisflyer
That's really steep, especially for an oil change! They charge around $90 in NC.
I will say that I wouldn't trust my worst enemies car at Jiffy Lube!
Old Jun 30, 2006 | 12:51 PM
BriNYU's Avatar
BriNYU
LOL, for entertainment's sake I just gave Jiffy Lube a call...$59 for 'quality oil'. I asked them how much it was if I brought my own Mobil 1 Extended Performance and they told me that they'd take off $3. (1 bottle of that Mobile 1 is $8 alone).
Oh woe is me...there's gotta be somewhere decent I can have it done...
Old Jun 30, 2006 | 12:53 PM
ekibobrut1's Avatar
ekibobrut1
oil change
do it yourself and save BIG bucks and it's done RIGHT !
Old Jun 30, 2006 | 12:57 PM
Rang's Avatar
Rang
Yikes Jiffy Lube. 3/4 of employees there dont even know which way to turn a bolt out, and the other 1/4 guess.
Old Jun 30, 2006 | 01:05 PM
kenchan's Avatar
kenchan
Patrick wants $180 for an oil change?!
there's got to be something else included in that service, i hope!!!
I would talk to other dealers in the area Knauz, BJacobs, etc. You can
also talk to www.Euroquipe.com in St. Charles. they can do
our cars.
Old Jun 30, 2006 | 01:47 PM
Yucca Patrol's Avatar
Yucca Patrol
4.7 quarts of Jiffy Lube oil is probably worth less than $3, so they are giving you a deal!
Those Jiffy Lube idiots will have ZERO idea how to remove and install your oil filter. They won't have the right tool and they won't be able to get the housing on, and if they do, they will almost certainly break the o-ring in the process, leaving you with an oil leak.
However, this would be the same quality work that I received at Global Imports in Atlanta when I had them do a "free" oil change, so you might be just as well off going to Jiffy Lube and saving the $$$
I know you say you are too lazy to do it yourself, but it takes a LOT less time to do it yourself than it would take to drive and wait for anyone else to do it.
Old Jun 30, 2006 | 02:16 PM
kenchan's Avatar
kenchan
actually, i let mine drip for like an hour... so i might take longer...
Old Jun 30, 2006 | 02:17 PM
tools's Avatar
tools
I was charged 65.00 at dealer. You must of had other things done to have been charged that price.
Old Jun 30, 2006 | 02:20 PM
Yucca Patrol
Me too, but I can go back in the house and enjoy a beer while I wait. . . something I can't do in a dealership waiting lounge.
Old Jun 30, 2006 | 02:26 PM
zer03s's Avatar
zer03s
Ok this subject brought my attention since I'm about to change my oil. This is my first European car and my question is, what's the difference between changing the oil of the Mini than changing the oil of a regular Japanesse car?
Old Jun 30, 2006 | 02:37 PM
planeguy's Avatar
planeguy
The filter design is just not idiot proof...
1. plastic cap = easy to strip threads
2. little o ring to seal cap = easy to bind or tear, causing a leaky seal
3. placement and removal = regular oil wrench wont work. you need a freaking huge socket i forget how big but you wont have it, also because of the way it is installed those grease monkeys will slop oil all over your exhaust header.
4. you should at least use OEM filter, the paper filter element design of lesser quality aftermarket filters have been known to collapse
translation....DO IT YOURSELF! If you have the time to sit in a jiffy lube then you have time to DIY.....
Old Jun 30, 2006 | 02:48 PM
usa_3388's Avatar
usa_3388
anyone knows how much dealer charge for oil change? I am living in
san jose, north california.
Old Jun 30, 2006 | 02:59 PM
Eric_Rowland's Avatar
Eric_Rowland
Correction/clarification -
1. Aluminum cap, not plastic. Still prone to crossthreading, though.
3. 36mm socket. If you're careful, no sloppage.
usa_3388, MMV's labor rate is $140, so odds are it would be in the range that BriNY experienced (assuming they charge an hour of labor.)
Come down to Santa Cruz, we'll do the change, walk to beach and have a burrito and a beer, and you'll be way ahead.
Old Jun 30, 2006 | 03:12 PM
zer03s's Avatar
zer03s
I guess changing the Mini oil is almost the same as changing regular Japanesse cars. So what is next after changing the oil? They said to do some resetting? Please tell me what's next. Thanks.
Old Jun 30, 2006 | 03:24 PM
Eric_Rowland
See the bottom of this post.
Note that if you're doing an 'in between' oil change during the service warranty period, you may want to leave the counter alone.
Click here for the entire MINI oil change How-to. Thanks to Randy Webb for the excellent documentation of the procedure!
Yes! The main trick is to hold the button until it says “51A; oil service –2675 miles”. This would probably be different depending on how long you wait to do this. Normally when you hold the button, then turn the key to position 1, the “test mode” activates instantly. But you have to keep holding until the oil service mode displays.
Here’s what I did:
- Press & hold the “Trip Button”
- Turn Key to “Position 1”
- Keep holding the “Trip Button” until the “test” displays changes to the “oil service” display.
- Press & hold the “Trip Button” until “rst” pops up and starts blinking.
- Press the “Trip Button” once more and release
- The oil service display should now show an “inspection” countdown instead of an oil service countdown.
- That’s it.
I hope this procedure is correct, since I was trying to attempt this numerous times until I finally got it.
Old Jun 30, 2006 | 03:42 PM
Jersey_Bill's Avatar
Jersey_Bill
Do yourself a favor ....
Buy one of these cuties -
http://www.fumotovalve.com/
And install it on your next oil change. After that you never need to worry about stripping threads (which is easy since the oil pan is aluminum I believe) - just turn the valve and drain your oil. They even offer one with a nipple so that you can run a hose from it to a container for zero chance of spillage.
I have one ready to be put on at 5,000 miles when I will do my first oil change.
Question (since I am too lazy to check) - does the JCW strut bar get in the way of changing your oil filter? I think I had heard that you need to remove the bar to get access to the filter cap...
Bill
Old Jun 30, 2006 | 03:46 PM
zer03s's Avatar
zer03s
Eric,
I just purchased a used 03 MCS with 37k and I think the service warranty is expired already but I normally do all the changing oil to my cars. So the question is, what happens if I don't reset the counter? Also is that the instruction on how to reset your counter? Correct me if I'm wrong, the counter of the change oil is where the speedometer is right? Mine says 9600 left. The reason I wanted to change the oil is because I bought it used. Can you reset the counter to any numbers? Thanks Eric.
trentf's Avatar
trentf
$192!
Best to save $$ and do yourself. It is too easy not to!
Checkout Motoringfile.com DIY section.
Be careful not to cross threads when reinstalling the canister/cap, and ensure the o-ring is seated fully before reinstalling as well.
Also...the drain plug may be super tight, so be prepared. (aluminium pan and steel bolt). I typically use a 10 inch breaker bar for leverage, but be sure that the socket does not slip off and round off the bolt head. A small amount of anit-seize on the bolt threads when reinstalling it may make it eaiser to loosen at your next oil change.
Really.....I paid $192 for an in between service interval oil change!
Old Jun 30, 2006 | 04:53 PM
chows4us's Avatar
chows4us
If you do not want to do it yourself (and many ppl dont have the time nor care to), DO NOT go to Jiffy Lube. Just get the OEM filter from a dealer (like Classic). Buy your own Mobil 1. Find a local independent shop that specializes in German cars (like BMW, Mercedes) or just European cars. They most likely will do it for you far cheaper than any dealer.
Old Jun 30, 2006 | 05:22 PM
Eric_Rowland
zer03s - yep, you're out of service warranty, but still within MFG warranty, so I'd just do the oil change, and leave the counter. If you reset it, it'll tell you that you have 15K to go until the next change. I'm not sure about how the counter interacts with the inspections vs. oil changes, so I'd keep the resets to the MINI specifications.
If you don't reset the counter, nothing happens. It will just keep counting down until it thinks you need an oil change.
Old Jun 30, 2006 | 05:34 PM
2006mcsasteve's Avatar
2006mcsasteve
Edge Motorworks in Dublin, CA - a shop that does a fair amount of work on Minis - charged me about $75. If you are not a do it yourselfer, definitely go to a shop that has experience working with Minis.
Old Jun 30, 2006 | 05:35 PM
rhawth99's Avatar
rhawth99
I thought the MINI was one of the easiest cars I've ever owned to change the oil on. Most cars the oil will drip down from the filter and get into every little nook and cranny. With the MINI, drain the oil through the drain plug, loosen the aluminum cover over the filter element, let it drain for 10 minutes or so (guess I drink my beer faster than you guys ), fully remove cover and filter (no remaining oil to drip all down engine), put new filter element on, put new gasket on cover, spin cover on, tighten cover and drain plug. Fill with 4.5 quarts of synthetic of your choice and check level. Nice, neat job. My 2002 Passat with the 1.8 turbo was a PITA to get at the filter and it always piddled over everything below it.
Old Jun 30, 2006 | 07:27 PM
T2Nav's Avatar
T2Nav
For budgeting purposes, how often must one change the Mini's oil? The traditional 3000 miles? 4 or 5 like it says in my truck instructions? Or does the synthetic oil last some extra distance I'm not familiar with? Thanks!
Old Jun 30, 2006 | 11:44 PM
Eric_Rowland
If you're budget minded, the car will tell you when to change it. This will be ~15K miles, which is supposed to be ok with synthetics. I can't imagine letting it go that long though.
If not, per Randy Webb - 5K miles for a street car, 3K if you do track days.
