R50/53 MINI Oil Change...
Originally Posted by Yucca Patrol
I know you say you are too lazy to do it yourself, but it takes a LOT less time to do it yourself than it would take to drive and wait for anyone else to do it.
But yeah, i say no to jiffy lube.
$180 just seems way too high for the dealership. Gad, I wish Adam were still at Patrick MINI
Me too, but I can go back in the house and enjoy a beer [Emphasis added.] while I wait. . . something I can't do in a dealership waiting lounge.
Originally Posted by Eric_Rowland
...I'll be doing it myself, thanks.
The main problem isn't the cost of going to Jiffy Lube or someplace similar, it's how they treat your car. I used to work for NAPA auto parts, and a big seller were oil drain plugs. Self tapping, over sized oil drain plugs, because the quick oil change monkeys were over torqueing the drain plugs on cars and stripping out the threads. Confirmed do it yourselfer.
Originally Posted by T2Nav
For budgeting purposes, how often must one change the Mini's oil? The traditional 3000 miles? 4 or 5 like it says in my truck instructions? Or does the synthetic oil last some extra distance I'm not familiar with? Thanks!
The manufacturer, the oil company, or yourself.
Yourself.....most people have little or no education or experience in chemistry or engineering yet seem to know exactly what is right for thier cars, mostly through what pappy always said.
Oil company, has a vested intrest in selling you more oil than you need. The 3000 miles was always a oil company recomendation.
Manufacturer.....Has a vested intrest in long term reliability and brand confidence, has hundreds or thousands of engineers and chemists...etc that know your car better than anyone else making a recomendation to you on brand, formulation and change interval
I follow the manufacturer instructions
I guess I'm one of those confirmed 3000 miles guys. I have a 1975 MGB I used to autocross and drive hard. At just over 100,000 miles I rebuilt the engine, and didn't have to do any machine work at all. Just replaced the bearings, gaskets and seals, and was good to go. Castrol 20/50 every 3000 miles.
Originally Posted by planeguy
It depends on who you trust.....
Manufacturer.....Has a vested intrest in long term reliability and brand confidence, has hundreds or thousands of engineers and chemists...etc that know your car better than anyone else making a recomendation to you on brand, formulation and change interval [Emphasis added.]
I guess I would feel a whole lot better about following the manufacturer's recommended change interval (otherwise known as follow the counter), if they had specified a change at the completion of the break-in period and if they had a longer warranty period. Even a powertrain-only warranty of say, 100,000 miles, and I would be following the counter religiously.
However, since it is my nickel after the first 50,000 miles, I am buying an insurance policy of sorts by changing at a 7,500 mile interval.
Originally Posted by caminifan
The manufacturer has your best interests in mind up to a point. Ultimately, the manufacturer has its best interests in mind, whiich means it wants to keep its warranty repair bills at a minimum and keep you buying its cars.
So, that is to say that if BMW wants to sell me another car, this car better last till 200k miles, on thier direction, or I will NOT be a return customer, nor will I recomend any of thier products.
I think a big problem is where you live... I live in a townhome complex, and they will not let you do ANY work on your car other than checking stuff or cleaning the interior... I started to think about it the other day, since I usually like doing my own oil changes... I'm just glad the MINI doesn't need one for so long... I was concerned at first that this seemed like a really long time between oil changes, but hey then I thought that if you are going by the manufacturer's suggestions and something goes wrong, it's their fault not yours!
Originally Posted by mini-mine
I think a big problem is where you live... I live in a townhome complex, and they will not let you do ANY work on your car other than checking stuff or cleaning the interior... I started to think about it the other day, since I usually like doing my own oil changes... I'm just glad the MINI doesn't need one for so long... I was concerned at first that this seemed like a really long time between oil changes, but hey then I thought that if you are going by the manufacturer's suggestions and something goes wrong, it's their fault not yours![Emphasis added.]
The real unanswered question is what process is best for long engine life? MINI is silent on that matter.
True, but I would submit that this is more like GM's philosophy than toyota's. I would even be as bold to say as this is why the big 3 market share is declining while Honda and toyota is climbing. I must admit though that it does not seem that BMW's last past 200k. But these long change intervals are common accross all brands it seems
My MINI is the first car I've ever owned, so I was unfamiliar with the regular oil changes every 3000-5000 miles or so.. I have gone 15,000 miles (by my own fault) without an oil change, and I would NOT recommend it. From now on I'll be changing my oil myself every 5000 or so with Redline.
On that note, I purchased some jackstands, an oil drain pan, and did my own work at home, and I still came out ahead. And I'll be able to use the stands for other things besides changing oil!
It took a while (around 45 mins) since it was my first ever oil change, but everything worked out properly! That drain plug is a pain to remove without sufficient leverage! And that 36mm hex for the oil filter is a pain to put back. I think it took 20 minutes just to put it in! I'm sure it'll take less time in the future.
Now that I've done it, it's easy as pie! And I'll save 100+ bucks every time by doing it myself!
Here's for DIY'ers!
Here's for DIY'ers!
There are a whole bunch of reasons why GM's market share is declining while Honda/Toyota's is increasing. A significant (maybe even the primary one) reason is the cost model differences. One example: because of the large number of retirees that GM has to cover health insurance costs for, the health insurance cost adds ~$1,500 to the cost of each car they sell. Honda/Toyota and the like don't have that (retiree health insurance) cost factor to deal with, so they are not as focused on cutting other costs (such as warranty repairs). Is that a level playing field? I tend to not think so.
Guy at a BMW service garage told me 7k for synthetics. I got mine used and the previous owner changed oil every 7500 mile religiously, so I am going to continue the trend. $80 a pop is pricey, but worth it in the long run!
Only if you are within the warranty period. After that, and it is your nickel.
Does synthetic oil burn off normally?
I happened to check my oil level the other day and was surprised to see that it was over 2 quarts low! I had assumed (maybe stupidly) that with the synthetic, the level would be fine in between the recommended oil changes as indicated by the service light. Anyway, my past experience with cars is that any burning of oil is a sign of something bad. I am at MINI to get a few other things checked and asked them about this and they told me that it is normal for the synthetic to burn off over time and that is why they recommend to check the level every time you get gas. This seems weird to me...anyone have any insight? From now on, I am not waiting for the service light and am going to go with more regular oil changes but maybe I am being paranoid...
According to different manufacturers, it can be considered 'normal' for a car to burn up to a quart every few thousand miles. *I* don't consider it normal, but they do. You may have gotten a 'loose' engine, with a bit less sealing around the rings so you get oil blowby. It has nothing to do with synthetic oil, IMO. (I didn't lose a drop in 4k miles)
Not much you can do other than checking the oil regularly
(which you should do anyway.)
One reason manufacturers used to have long oil serive change intervals is those numbers are used to calculate "cost of ownership." Cost of ownership is often sited by car magazines and consumer product reports.
In the 80's, when synthetics weren't common, most owners manuals recommended oil changes every 7,500 miles. To me that seemed excessive and everyone, including dealers, recomended changing the oil every 3,000 miles. Surely, synthetic oils last longer and maybe changing it every 10K does no harm. Mini recommends the first oil change at 10K. It just made me feel better to change the "break in" oil at 2K. Maybe I wasted money but, since I did it myself for less than $40.00 (OEM filter and Mobil 1 synthetic) peace of mind was worth it. I'll change it again at 6K, let the dealer do it for free at 10K. After that my oil will be changed every 5K (do it myself every other time until the free oil changes run out.)
I understand everyone doesn't want to, or can't for various reasons, change their own oil but paying anything more than $80.00 seems excessive.
BTW, there are some good posts on NAM which give very detailed instructions on how to do it yourself.
Jiffy Lubes horrible, in my old VW they took down the skid plate and let the oil pour down it and then just put it right back, and it still cost $90 ridiculous.
And cause they didnt attach it right, i drove for a day or two with it hanging and had to replace it:-(
Find yourself a good local independant mechanic through one of your local clubs, That's what I did. I took my 2002 MCS to the dealer and I was quoted $280 for the "oil service" I said to the SA "what does that include/" He said "oil ,filter and lube". (I wonder if he meant a lube for me too) anyways, local mechanic charged me 344.00 but I got oil change, filter, lube rotated tires, K & N drop in air filter, cabin air filter, brake flush and replaced with blue high temp brake fluid, adjusted brakes ...There has to be a place that does MINI's where you live. I would rather give that money to an honest mechanic than to the dealer..
