R50/53 Possible to add multifunction controls on standard steering wheel??
I don't know if this is possible or not, but I'm hoping it's as easy as I'm thinking. I have a 2005 MCS w/ the standard steering wheel and would like to add the steering wheel controls for the audio. Is it a matter of taking out the two pieces on the steering wheel and purchasing the other two. For example, is there a cable that I can just plug the controls up to and it will give me compatibility?
Again, I doubt it's that easy. I was just hoping someone knew what I was talking about and already tried it out.
Originally Posted by Agro
From memory, I don't think you can even swap a MFSW for a standard steering wheel and make it work. I think the wiring is not installed.
Standard MINI Retrofit kit
Yeah, but that retrofit kit is for the old 2-spoke steering wheel (2002-2004 production) not the current 3-spoker sold in new US spec MINIs.
If you have the 3-spoke steering wheel you may be SOL, unless the steering wheel can be swapped for one that has the MFSW buttons. I don't know whether the wiring is present or not.
Its going to be expensive. Much cheaper to spec it from the factory.
Originally Posted by CustomAV
You may want to check with 770 KOF and ask Alan how much for his 3 piece wheel. I am not sure if it is MFSW but he has a JCW so it may be. You may find that a new wheel will be cheaper and have the wiring harness already so you don't need the retrofit kit.
chris
chris
http://www.realoem.com/bmw/showparts...26&hg=32&fg=95
I see now. They have separate part numbers for pre-7/2004 production and post 7/2004 production.
This link maybe of interest to the original poster:
http://nemini.org/Forums/viewtopic/t...ing+wheel.html
Not exactly the same situation. In this case, the owner of this MINI replaced the factory 3-spoke MFSW with the older 2-spoke MFSW. Price tag to do the job (including parts): $1,300! (Ouch!)
Powershift
Aug 16, 2015 05:14 PM
Navigation & Audio Steering wheel controls for music
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
