R50/53 Question about the JCW LSD
Old Mar 7, 2006 | 05:40 AM
v1k0d3n's Avatar
v1k0d3n
I haven't bought the mini yet...but putting money down this week .
I have a question about the LSD for the JWC...it's a 1.5 LSD right? I can't find a lot of info on the net about this...also is it mechanical or electronically controlled?
Old Mar 8, 2006 | 06:14 AM
v1k0d3n's Avatar
v1k0d3n
hummm....
Stupid question??? am i missing something? :(
Old Mar 8, 2006 | 07:29 AM
Coopernicus's Avatar
Coopernicus
It is mechanical, and appears to be geared with no clutches or plates, though this is supposedly a unique 'hybrid' design.
I BELIEVE the following to be correct:
  • It is the same unit used by BMW in the current ///M3.
  • It has a "1.5-2.0 ratio".
Here's a link to the manufacturer's (rather sparce) description of this unit, with a piccy:
GKN 'Super LSD' Website
BFG9000's Avatar
BFG9000
The factory LSD is an Auburn-style friction unit that uses nonrebuildable cone-type clutches. The unit is rated at a rather loose 30% so as not to understeer you off the road or interfere with ABS. More here: http://www.motoringfile.com/2004/12/...p_differential
Old Mar 8, 2006 | 10:30 AM
jibeho's Avatar
jibeho
So when the clutches wear out you have 2 options. Live with a open axle or drop 3-4 thousand beer credits for a new unit?
Old Mar 8, 2006 | 11:45 AM
v1k0d3n's Avatar
v1k0d3n
dddaaaaaamnnn!
Old Mar 8, 2006 | 06:17 PM
BFG9000's Avatar
BFG9000
Well that is the way the Auburn has always been... the friction materials are the side gears and housing themselves machined into a cone-shape for greater surface area. This provides the very smooth and progressive lockup needed to not mess up the steering in a FWD. When they wear out they are replaced as a unit... only BMW doesn't sell it separately from the transmission.
When it wears out you can get a gear-driven Quaife. Those don't wear out.
Old Mar 8, 2006 | 06:26 PM
lhoboy's Avatar
lhoboy
That's my plan.
Old Mar 9, 2006 | 12:55 AM
-Jonathan-'s Avatar
-Jonathan-
Damn! I didn't know that! How long does it take to burn out a LSD? How do you know when it's starting to burn out? Can I get 200,000 miles with the factory one, or am I dreaming?
Old Mar 9, 2006 | 08:53 AM
SilverRocket's Avatar
SilverRocket
Given proper maintenance and a non-defective unit, how long it takes to wear out the factory LSD will probably depend on how much time it spends doing its thing (ie:how hard you drive the car).
If it dies within the warranty period it should be replaced w/o charge unless your service department are pr*cks or have evidence that genuine abuse was the cause of failure. Out of warranty, I'd replace it with the Quaife as others suggested.
Have people had problems getting their service departments to cover these under warranty?
Old Mar 9, 2006 | 05:26 PM
Crashton's Avatar
Crashton
Have people had problems getting their service departments to cover these under warranty? __________________
I'd be surprised if anyone has had one of these wear out yet. I think it should last a long time under normal use. Yep even if you kick it a bit.
Old Mar 9, 2006 | 10:25 PM
-Jonathan-'s Avatar
-Jonathan-
Hopefully it should last me at least a few years. Being only 17, hopefully I bought an option that will last a while without the need for maintenance every two seconds. (exaggerating)
:impatient
Anyone have more information about the durability of the LSD?
Old Mar 10, 2006 | 07:41 PM
lhoboy's Avatar
lhoboy
When the car pulls to the side during straight-away accelleration. That's what mine did before I retrofitted with a factory LSD.
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
Minibeagle
Aug 13, 2015 10:00 AM
nomar116
Aug 10, 2015 11:24 PM
papawhiskey
Aug 10, 2015 09:31 PM
