R50/53 Have you found the amp?
Old Feb 5, 2003 | 01:39 PM
yellowdesmo's Avatar
yellowdesmo
I have the H/K stereo in my Mini and was wondering if anyone has found the amp.
The reason I'm asking is, does the amp have a gain on it?
Old Feb 5, 2003 | 01:44 PM
Davbret's Avatar
Davbret
Amp should be in the passenger side cubby hole in the boot.
R
Old Feb 5, 2003 | 05:36 PM
jbs111's Avatar
jbs111
I have the Hk and the amp is in fact in the passenger side cubby hole in the boot
JB
Old Feb 6, 2003 | 01:19 AM
CharlesWil's Avatar
CharlesWil
FYI - I'll post this one more time:
From AskMINI
Hi Charles!
I found the information regarding the Harmon Kardon sound system that you requested. The Harmon Kardon has a total of eight speakers:
o Two Front Tweeters
o Two Front Loudspeakers
o 2x2 Rear Loudspeakers
The total system power is 320 watts and it utilizes an external audio amplifier located in the right rear cargo area.
I hope this helps! Let us know if you have any more questions.
LET'S MOTOR.
Jen Schuelke
MINI Division
Customer Relations
Charles
Old Feb 6, 2003 | 09:53 AM
yellowdesmo
Yes that does help thank you, Thank you all for the info.
Old Feb 6, 2003 | 10:07 AM
Ryephile's Avatar
Ryephile
why do you want to adjust the gain? I'm guessing you'll want to turn it up, however this will only decrease your signal to noise ratio and increase distortion. If you're turning your head-unit all the way up and it's still not loud enough, you'll have to resort to a higher-powered aftermarket install. The OEM Audio team has designed the system to run with a fixed gain, and messing with that will only screw it up. Since it's an OEM system, there won't be an adjustable amplifier gain.
Filmy
Apr 28, 2019 11:37 AM
Filmy
Sep 7, 2015 08:27 PM
Filmy
Sep 7, 2015 11:27 AM
jesterofatlas
Sep 4, 2015 11:23 PM
hardy616
Sep 2, 2015 08:32 AM
