R50/53 Rough feeling through brake pedal that comes and goes. ABS, ASC light come on
Old Mar 5, 2026 | 01:10 PM
john411's Avatar
john411
Then it'll just go away. Last time this happened was three weeks ago and I changed all rotors and brake pads. Anyone know what this could be. When this happens the brake pedal almost feels like there is a crunching to it but then just goes away.
Old Mar 5, 2026 | 01:54 PM
phone_cover's Avatar
phone_cover
are you saying you had the issue, swapped everything brake related,have no change? there are only so many options.
"crunching" sounds like maybe a wheel bearing.
the other easy thing would be the CV axles.
have you put it up on stands and spun the tires? do you have an idea of which side is making the noise? what other troubleshooting have you done?
Old Mar 6, 2026 | 03:51 AM
john411's Avatar
john411
I didn't put it up on stands
The axles are less then a year old. The strange sound only happens once in a while. I'll have to go under the car and check it out
Old Mar 6, 2026 | 06:51 AM
cooper48's Avatar
cooper48
The ABS/ASC lights are triggered by the wheel sensors. When doing the brakes were those replaced or detached in some manner?
Old Mar 6, 2026 | 09:41 AM
john411's Avatar
john411
The mechanic replaced two but said the other two he couldn't because the pigtails were bad and disconnecting them would break the plastic of the pigtail
Old Mar 6, 2026 | 02:17 PM
cooper48's Avatar
cooper48
That's a common problem on older MINIs. Here's a link to a pigtail to splice into your wiring that will replace your broken component. I used these when I replaced the sensors on my MC40.
https://www.ebay.com/itm/19742480425...sNBDlT0ig4qJ5c
Old Mar 7, 2026 | 05:41 AM
phone_cover
you can also get the plugs themselves. i bought new plugs, broke off the old ones, and installed fresh plastic w/o having to splice any wires.
Old Mar 7, 2026 | 08:05 AM
ssoliman's Avatar
ssoliman
+1 this is common. happened on both my mini's. they can be replaced
Old Mar 7, 2026 | 05:39 PM
john411's Avatar
john411
Thanks. I'm really hoping this does the trick
sevin
Sep 24, 2015 05:00 AM
skiman747
Sep 17, 2012 11:11 AM
a5sh5te34
R60/R61 Stock Problems/Issues
Jan 4, 2012 07:05 AM
BUZZNBI
Aug 21, 2011 07:58 PM
