R50/53 2003 S snapped battery bracket bolt with battery still in kar
i went to remove/replace my battery in the hatch of my 2003 Cooper S & snapped the battery bracket hold down (long) bolt while the old battery is still in the kar
with the old battery still installed i can't seem to get in there with vice grips to remove the broken hold down bracket bolt to free up the battery for removal
anybody got any ideas for me to remove my battery without really mucking things up?
A picture would help.
Pending that:
If the other (closer to the car's front) bolt comes off, bend back and/or turn the bracket enough to clear the battery. Then bend it back / replace it once you get the rusted / seized bolt sorted (which itself may need to be cut loose from the bottom). Worst case cut the bracket and replace it with a new or good used one:
https://www.pelicanparts.com/search/?q=61216917738
https://www.ecstuning.com/b-genuine-...t/61216917738/
https://www.outmotoring.com/_search....38&categoryid=
Pending that:
megaDan, can't take to it, the battery is in the way ....that's the issue, i can't get in that little space
Daftlad, yup, looks like that's way i have to go, i'll just have to replace the long bolt & lock down tab if everything goes smooth (when does it ever) but that's the plan ........maybe even a screwdriver to help bend the lock down tab
sorry about no picture i'll take one in the tomorrow when i beat that battery out of me kar .....thanks for your suggestions/ideas
hmm, water in the battery box?
I had this happens to me too. I used to get a lot of water in my battery box due to leaks. My long bolt snapped below the clamp, fortunately, so the bracket wasn’t stuck.
Once everything was out, I ground the bolt stub flush, drilled a hole, and re-tapped threads in the hole with a tap on an extension.
WhoHasGotTheBlueS
i was wondering if you went back to the stock long bolt?
& if not what did you use as a replacement/solution?
https://www.realoem.com/bmw/enUS/sho...diagId=61_1591
Yes, I stuck with stock, p/n 61-21-7-577-620. (Other vendors also have this screw but do not list the number as having a MINI application). I applied anti-seize paste to the threads at the time of installation, for good measure.
thank you everybody for your input
I don't remember, sorry. I don't know why they don't list the thread size in the part description...
..........thanks again guys for all your input
Geez, I had several leaks. I replaced the third brake light and the hatch handle gasket. Seems like there's another, which I am not recalling right now...
JohnRSail
Oct 23, 2016 04:34 PM
R50/53 MINI Battery Bracket issues
plantain
17
Oct 8, 2007 08:53 AM
