R50/53 06 base stalling wont stay running
Old Apr 17, 2022 | 03:37 AM
tbrin1's Avatar
tbrin1
Brand new to this forum and have read many posts, hoping someone can help, So, my son’s 06 base cooper bogged down and stopped running at a stoplight. Said it seemed like it just was losing power then stalled and won’t start. When he tried to restart it would start running for about a sec or two and then die. He is in college and it’s just a car to get to points a and b. but at this point, it isn’t doing that. I had the car towed home to start diagnosing the problem. I’ve looked all over the web and have tried a few things with no luck.
When I replaced the Purge valve, I got the car started and it ran and drove then went back to the same problem. Didn’t know if that helped or just started by luck. I could tell it was not going to start again when it would start to lose power while driving. If you get it started again when you are in park it will only rev to around 3,500 and start to bog. Not sure if this car has a rev limiter in park and neutral or if it is still in limp mode. Everything I have done I do one at a time to keep the variables constant.
Here is what I’ve tried or replaced. New ignition coil, new plugs – old plugs looked fine when removed, new plug wires, new purge valve, new map/MAF sensor (not sure on this car what it is called), new cam position sensor, new coolant temp sensor, the battery is fully charged, new gas cap and I have checked the vacuum lines for any cracks. I haven’t done a smoke test yet. Plan on testing fuel pressure at the rail this week. You hear the pump start when the key is switched. Turning on and off a few times to “prime” the injectors as some suggested, doesn’t make a difference. Could it be the fuel pump and fuel filter even though when it does get running it is running fineish?? Little frustrating at this point. Any suggestions would be greatly appreciated. Thanks
Old Apr 17, 2022 | 05:18 AM
AcidK1's Avatar
AcidK1
o2 sensors? Have tou got anything to read there outputs at all?
Old Apr 17, 2022 | 05:43 AM
tbrin1's Avatar
tbrin1
I do. I will try the o2 sensors and report back the findings. Thank you
Old Apr 17, 2022 | 06:55 AM
adriancl's Avatar
adriancl
Try to remove Throttle body , clean the throttle flap, put it back and do throttle adaptation with a diagnosis tool.Maybe will solve the issue.
Old Apr 17, 2022 | 08:05 AM
tbrin1's Avatar
tbrin1
Cleaned throttle body and same result. Checked o2 sensors and got .03 reading ohms cold. Can't read data live since the car won't stay running. Shouldn't the ohm's be between 10-20?
Old Apr 17, 2022 | 08:09 AM
adriancl's Avatar
adriancl
engine run with bad O2 sensor, is not about O2 sensor.What fault code you get with diagnose tool?
Old Apr 17, 2022 | 08:53 AM
tbrin1's Avatar
tbrin1
Central Body Electronics(ZKE)0,D1H/209 Slew of other codes from wiper to high low beam. 18H/24, 2H/2,1,BH.11. Checked all fuses all check out. Had same kind of issue with my X5 throwing so many codes turned out to be the battery. Dealer didn't regester the batter with the x5. do you have to do the same thing with a mini? This battery holds a charge. The car drove fine until this.
No indications leading up to the first stall out.
Old Apr 17, 2022 | 09:01 AM
adriancl's Avatar
adriancl
R50, R52, R53, no need to register battery.Only R56 can loose FRM memory when battery is disconnected.FRM=ZKE
Old Apr 17, 2022 | 09:57 AM
AcidK1's Avatar
AcidK1
My car really bogged down when my o2 sensor went, to the point it was worse then limp mode, never cut out but it was worth a try.
Old Apr 17, 2022 | 11:43 AM
Here2Go's Avatar
Here2Go
NAM Community Team
FWIW - I almost always suspect fuel starvation....but that's just me.
Did the pressure at the rail fall within range? When was the last time the fuel filter had been changed?
Old Apr 17, 2022 | 05:47 PM
ChiefM's Avatar
ChiefM
I agree with Here2Go on fuel pressure loss. Both are easy to access under the rear passenger seat.
My R50 would run and drive but idle like poop. Changed the fuel pump and filter and no more issues.
Old Apr 18, 2022 | 02:03 PM
tbrin1's Avatar
tbrin1
Checking rail pressure this week. Changed out the 02 sensors, no change. I don't know about the fuel filter. Probably going to change the pump and filter anyway..
At this point, it will have had a heck of a tune-up.
I'll post after the weekend with updates.
Old Apr 18, 2022 | 02:58 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Yeah.
Remember "back in the day"....If your car was running crappy; All you had to do is pop the hood and look through that clear plastic thingy spliced into your fuel line to see if it was dirty?
*sigh*....
Those were the days
Old Jan 16, 2024 | 08:11 AM
Adrian Adam Zywno's Avatar
Adrian Adam Zywno
Did the OP ever find out the culprit?
My 2005 R53 had power loss/bogging while driving in gear, then gave out when I got to an intersection. Would start up but die in a second or two. Looked at ground points, vacuum connections, spark and attempted to start a handful of times which ended up in just crank and no start.
Now I have gotten the car back to a brief start scenario after pressurizing the fuel system with an on & off of the ignition a few times. Does anyone know if that's a clear indication of anything like the fuel filter, pump, regulator, injectors, etc?
Appreciate any advice!
Old Jan 19, 2024 | 08:00 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
In addition to a bad fuel pump, if the seal is not correctly seated on the fuel filter/pump top or is faulty, the car will not start.
Edoardo Marzi
Nov 27, 2019 11:34 PM
Nemesis342
Apr 23, 2018 01:11 PM
TheBlur
Feb 21, 2017 06:17 PM
Babukb2
Dec 2, 2015 05:20 PM
craigsmiller
Jun 13, 2013 12:51 PM
