R50/53 Part help - supercharger pushlock fitting.
Old May 4, 2021 | 06:38 AM
gforce1108's Avatar
gforce1108
I’ve seen places that carry the new plastic ring to secure the breather tube, but not the fitting itself. I have a thread going on chasing a P0130 code and found a decent leak at the fitting with my smoke tester. The hose is good and locks in fine but something is leaking a decent amount. Is this fitting removable/replaceable?
Old May 4, 2021 | 08:57 AM
cooper48's Avatar
cooper48
Supercharger tube clip -- WayMotorWorks has these clips for $44 shipped. An absolutely ridiculous, and insulting, price to be sure but they're no longer available via OEM sources. You might check with RPM Mini Parts & Service in Irving, TX. They carry quite a few used parts and might be able to help.
Old May 4, 2021 | 09:26 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
I believe there's an o ring inside there check to see if it's still in place, the red clip will come out.
I source them at junkyards, they do not even charge me for them
Old May 4, 2021 | 01:12 PM
gforce1108's Avatar
gforce1108
I'll pull it apart to see if I can clean the oring. I should have measured the diameter of that tube. I have all sorts of pushlock fittings at work. Do you know if that whole fitting is removable?
Old May 4, 2021 | 07:24 PM
cooper48's Avatar
cooper48
F.Y.I. for all you Mini owners out there with 3D printers: This would be a very lucrative part to print and sell on this forum as it's no longer available as an OEM option via the dealer.
Old May 5, 2021 | 03:56 AM
MrBlah's Avatar
MrBlah
it's also not a good candidate for printing, too small, must flex to snap in without breaking
Old May 6, 2021 | 08:56 AM
gforce1108's Avatar
gforce1108
I have piles of SMC push-loc fittings at work just none in 9mm. I'd pipe thread a fitting in there before paying $44 for one of those clips!!! I didn't try too hard to remove the fitting - it spins, but doesn't seem to thread out. I applied sealant around the edge since I couldn't see if it was leaking at the hose connection or around the base. I also cleaned the oring without removing it. Worst case - I'll JB weld that tube in there!
Old May 6, 2021 | 01:22 PM
cooper48's Avatar
cooper48
There are 3D print filaments with inherent flexibility:
https://www.matterhackers.com/store/...0Series%20Flex
Dfly1972
May 20, 2020 07:24 AM
Ruben C
Apr 1, 2019 11:56 PM
CoopDr53
Apr 12, 2015 10:07 PM
RHcoopers
Apr 30, 2014 06:30 PM
fourblades
Oct 8, 2013 09:44 PM
