R50/53 Desperate for help after supercharger service
Old Jul 28, 2020 | 10:31 PM
seandallen's Avatar
seandallen
Friends:
I’ve been able to help a few people here and I hope I’ve banked some good karma.
‘05 MCS 111k miles.
I like to be proactive, so thought I would do the change the supercharger oil because I’ve read they have a tendency to fail if not serviced around this time. So I get the supercharger out, empty the stinky black oil, and open the ends. I cleaned everything out, changed the gear/pulley coupler to a polyurethane one, put it back together, and measure new oil into both ends.
I start putting everything back together. On the way back out, I put in a new water pump, crankshaft position sensor (with O-ring), blowoff valve, drive belt tensioner, new belt, spark plugs, thermostat & housing, a new gasket for anything that got touched. I dropped the oil pan to inspect and replaced the pan gasket along with an oil change. Of course, the coolant got flushed when I took the radiator off.
i cranked the car up still on the stands, before I put on the bumper, and had no error codes. The engine ran well put revved high for 1-2 seconds at start, and had a dip in RPMs every 10 seconds or so, but sounded good.
The next day when I got the car off the stands, I eased it out for a spin. It ran fine for a few hundred feet then went into limp mode. I had two errors, listed below, so I cleared them and went around the block again. Same result. It still revs high on startup.
The two (hex) error codes are:
1109 DME: Pressure sensor, intake manifold - input too high with trailing throttle
1689. DME: Electronic throttle monitoring, level 2/3, torque calculation - error
If anyone has had this happen before, or has a really good idea what the problem is, I would really appreciate the help. Thanks, everyone.
P.S. The car is bone stock, except for the stereo.
Old Jul 29, 2020 | 03:25 AM
nd-photo.nl's Avatar
nd-photo.nl
I did the same maintenance not to long ago. I also had a failing TMAP sensor (the one in the intake manifold) after refitting everything. In the end I found out that the connector wasn't making good contact with the 4 pins of the TMAP sensor. I used a small pick to bend the clips inside the connector, so that they are "smaller". That fixed the issue in the end for me.
With a little bit of luck, that will also solve the 1689 error.
Old Jul 29, 2020 | 06:10 AM
seandallen's Avatar
seandallen
Thanks. I'll check this.
Old Jul 29, 2020 | 05:27 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Could 1689 be from a unplugged or going bad throttlebody ?
do a throttle reset and see if it helps that one maybe .
Old Jul 29, 2020 | 06:12 PM
Macsplinter's Avatar
Macsplinter
Getting parts together to take the plunge. A little intimadated.
Old Jul 29, 2020 | 06:18 PM
seandallen's Avatar
seandallen
So I cleaned the throttle body before I put back on. I put a new gasket/o-ring in. I put some dielectric grease in the connection and it’s snapped tight. It looks like it’s working.
i don’t know how to do a throttle reset, and I don’t think my Foxwell 510 gives me the option.
any other ideas?
Old Jul 29, 2020 | 09:34 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Inpa. You can reset all your adaptations. Fuel,throttle an even transmission if it is an automatic.
Old Jul 29, 2020 | 11:13 PM
MVPeters's Avatar
MVPeters
Throttle reset is ignition on, engine not running, floor the gas pedal & hold for 30 seconds, release, key off & out.
Old Jul 30, 2020 | 04:52 AM
seandallen's Avatar
seandallen
i tried this but no joy. Thanks.
Old Jul 30, 2020 | 04:53 AM
seandallen's Avatar
seandallen
I’m not opposed to this, but I’m in a time crunch. What would I need?
Old Jul 30, 2020 | 03:29 PM
seandallen's Avatar
seandallen
Update: I thought it be several things, but most likely a vacuum leak. I found it.
it was on the underside of the new intercooler boot. Reseated it and runs like a champ.
Old Jul 30, 2020 | 06:06 PM
Macsplinter
Glad you got it going.
Old Jul 31, 2020 | 01:23 AM
nd-photo.nl
Nice! Start enjoying it again
Old Jul 31, 2020 | 07:21 AM
user 7389739's Avatar
user 7389739
Just curious what brand / model boots did you install? Any recommendations / tricks on how to avoid this happening?
Old Aug 1, 2020 | 07:36 PM
seandallen's Avatar
seandallen
I used the original MINI brand. I purchased them from RMEuropean, whom I recommend. I paid $91.14 & $52.76 for the two boots, respectively. The only advice I would give is to slow down (and I already work pretty slowly :
It's a little tricky to get them set in there when you're trying to get the intercooler on. Another pair of hands helps.
Old Aug 2, 2020 | 03:59 AM
nd-photo.nl
I went with MTC Motorsport ones, bought on eBay. Fitment is 100%, although it makes installing the intercooler maybe a little harder, due to reduced flex from silicone hoses.
Its a UK seller btw > https://www.ebay.com/itm/264621973761
speedman
Sep 3, 2019 06:33 PM
thinwall
Mar 26, 2018 05:28 PM
Honeybadgers
23
Oct 4, 2016 01:29 PM
crazyworld
Feb 15, 2014 11:29 AM
Hochspannung
May 10, 2013 12:52 AM
