INPA help..... please
Old Jul 27, 2019 | 10:29 AM
solomio's Avatar
solomio
I recently got an airbag light pop up on a 2006 MCS conv. Now I know these codes can't be erased and read by a regular code reader (of which I have a few).The recall for the airbag was done, so it's probably not that. I figured, what better time to get one of those cables and play around with my Mini. My ebay purchased cable is a K+DCAN and the listing said it was compatible with R52 of my year.
The software included with the cable doesn't seem to install well, and some software pack (Mike's tools something or other) I found on a BMW forum doesn't list any Mini models when I start INPA. Do I need a special Mini version of INPA? My understanding is INPA is what I need for my airbag light (unless I am wrong). My cable seems to work, since it seems to be recognized when connected to the car.
Old Jul 27, 2019 | 11:22 AM
mslatter's Avatar
mslatter
I wish I’d documented this better because I’m sure there are steps I forgot, but here’s the basic idea at the bottom of this thread. The real magic is GTECKO’s work. He or she deserves all the credit.
https://www.northamericanmotoring.co...ml#post4450602
Old Jul 27, 2019 | 07:58 PM
solomio's Avatar
solomio
Thanks for your response.So I downloaded the "Mini Cooper Coding" folder. I installed the Mini Cooper Standard Tools 5.0 --> INPA,NCS EXPERT software following the instructions to the letter. When I start up INPA, I am not getting an options to choose a chassis (in fact none are listed)
Old Jul 28, 2019 | 09:11 AM
mslatter's Avatar
mslatter
Assuming you followed all the instructions successfully (the critical one I think being running LADEN.BAT from c:\NCSEXPER\DATEN\R50), then maybe you're OK. INPA doesn't offer me any choices, either. When I'm connected to my car, it just shows me two green indicators to say that it connectedI then quit INPA and go launch NCSExpert, which eventually offers you a choice of models. This is documented in "Guide to Mini Cooper Coding II.pdf" in GTECKO's package.
Old Jul 28, 2019 | 10:46 AM
solomio's Avatar
solomio
So, partial victory. I was able to install INPA and the chassis R50 shows up (I am assuming this is what I should use even though mine is an R52). I am able to read ECU codes fine, but when I get to the Airbag, I get an error " ifh-0009 no response from controlunit". Now by reading around here and other forums, my understanding is that pins 7 and 8 should be joined. I opened up the cable and they are not. Should I be jumping these two for my model of car?
Old Jul 28, 2019 | 01:37 PM
solomio's Avatar
solomio
Just to update my own thread. Figured I had nothing to lose by jumping the two pins (I could always undo it if it didn't work). That did the trick. I was able to read and clear the airbag light. Now to figure out just why it went off but that's an adventure for another day. Special thanks to mslatter, you're a star !!!
Old Jul 28, 2019 | 04:36 PM
mslatter's Avatar
mslatter
Glad you got it worked out. All credit to GTECKO for sharing his work. Did you also get ISTA running? It’s got a better interface, and will give you text explanations of codes, etc. I think I got it from a BMW software site. It installs next to this stuff, and all you need to tell it is to use the default Ediabas setup for communication, and it will piggyback onto the stuff you setup today and (hopefully) just work.
Old Jul 30, 2019 | 06:09 PM
o2sys's Avatar
o2sys
I have a 04 MCS and use INPA with a cable that does't have pins 7 & 8 joined (but do have an adapter for the cable that does bridge them). I've tried both ways with 7&8 bridged and unbridged and for me it works fine both ways.
Old Mar 3, 2020 | 01:24 PM
joeldc13's Avatar
joeldc13
I solomio
Can you explain how you've been able to show the R50 chassis ? I am in the same problem, It seem that i'm missing the R50.ENG file
Old Jun 3, 2020 | 09:48 AM
Shane Maitland's Avatar
Shane Maitland
hi I have the exact same issue. no R anything. if I follow the guide above then not even the bmw e is listed. please help
Old Aug 31, 2020 | 10:34 AM
Thierry-77's Avatar
Thierry-77
I tried INPA 5.0.2 and R50 is showing but not on 5.0.6 .
it's strange , normally with the 5.0.6 we should be able to have the R50
Old Aug 31, 2020 | 11:51 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Anyone needs i have the latest dates files for R50 to R53. Just pm me your email. I will send file.
Old Aug 31, 2020 | 11:54 AM
Thierry-77's Avatar
Thierry-77
I have the last update thanks .
do you use INPA 5.0.2 or 5.0.6 ?
Old Aug 31, 2020 | 05:28 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I'm using version 5.00. I know when I first installed inpa. I did not have an option for mini r50. So I had to add the line. Now I have R50,R52 an R53.
Old Nov 12, 2020 | 08:19 AM
Keaton Waldo's Avatar
Keaton Waldo
R53 file!
I have the r50 in inpa, but it’s saying “R50 ident and error memory”.
can you please send me the file :(
also how would you go about adding the line?
Old Nov 12, 2020 | 08:31 AM
Thierry-77's Avatar
Thierry-77
I'm also interested for this
Old Nov 12, 2020 | 08:32 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Post some snap shots of your screen
I'm not at my house to send file. Message me your email.
Old Nov 12, 2020 | 04:06 PM
ssoliman's Avatar
ssoliman
I have a thread here titled “inpa” with full instructions. If u can’t find it let me know I will dig it up
Old Nov 12, 2020 | 04:56 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Here is a link to the latest R50, R53 daten files.
https://drive.google.com/file/d/1yjU...ew?usp=sharing
BMW Coding Tool ( There is no virus on this file ) Your browser may state there is.
https://drive.google.com/file/d/1Wi7...ew?usp=sharing
Old Dec 28, 2020 | 01:18 PM
Ryan Shoquist's Avatar
Ryan Shoquist
The second link no longer works.
Old Dec 29, 2020 | 07:38 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I will try to redo the link tomorrow.
Old Dec 29, 2020 | 07:39 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Send email. I will try to send it.
Old Feb 16, 2021 | 01:53 PM
shafiq ladha's Avatar
shafiq ladha
Will the r53 datens work for the r60?
Old Feb 17, 2021 | 10:48 AM
adriancl's Avatar
adriancl
No
Old Mar 8, 2022 | 08:28 AM
bstanz1's Avatar
bstanz1
How did you load INPA so the R50 showed up in the menu?
