R50/53 Suspension questions?
Old Jun 16, 2019 | 01:58 PM
alconk's Avatar
alconk
I just recently replaced the oem struts on my 05 MCS that had 136k miles and thought it would make a big difference in ride quality due to the oem struts were wore out but I was wrong. I seems to be stiffer and there is a 7 mile section of highway I take to work everyday and it bounces me to death. The struts I replaced them with are Bilstein and also replaced the strut tower bearings and LCA bushings. So is this normal?
Old Jun 16, 2019 | 02:52 PM
ItsmeWayne's Avatar
ItsmeWayne
I would say yes, as the new ones are tighter than the worn out ones. These are made to handle, which means the suspension is set stiffer that a normal street car!
Old Jun 16, 2019 | 02:54 PM
alconk's Avatar
alconk
Ok thanks do you think that was the right decision to go with Bilstein or should have went back to oem?
Old Jun 16, 2019 | 02:59 PM
ItsmeWayne's Avatar
ItsmeWayne
Bilstein shocks are a good street set up, so all is good! They should last a good long time too!
alconk's Avatar
alconk
Ok thanks!
Old Jun 17, 2019 | 04:00 AM
veedubpat's Avatar
veedubpat
The stiffness you’re now experiencing is common with Bilstein replacement struts. Bilstein runs high initial gas pressure on their offerings. You won’t be ill-served by them, certainly.
Old Jun 17, 2019 | 08:54 AM
alconk's Avatar
alconk
When I was looking for something to replace them with Bilstein claims oem ride quality and since they are a good quality part that’s why I chose them. Is there a different strut out there that would b a little softer?
Old Jun 17, 2019 | 10:04 AM
ItsmeWayne's Avatar
ItsmeWayne
Of course there is, but if you are running run flat tires, get rid of them first! Then your ride will be better!
Old Jun 17, 2019 | 10:39 AM
alconk's Avatar
alconk
Just bought new ones..
Old Jun 17, 2019 | 10:49 AM
alconk's Avatar
alconk
Ok got some new different tires coming and will go on tomorrow.
Old Jun 18, 2019 | 10:57 PM
alconk's Avatar
alconk
Well got the new tires on today and yep the ride is smoother.just hope I don't get a flat now.
Old Jun 18, 2019 | 11:47 PM
Blue R50's Avatar
Blue R50
Remember too that these cars do not ride smoothly even when new. They have a short wheelbase and spring rates set for good handling and as such are compromised more for performance than comfort. They also do not have a lot of compression travel. As such, they aren't really well suited to places with lots of poor quality roads. Where I live, in Florida, most of the roads are smooth with few potholes because of the lack of freezing temperatures and frost heaves. I have the Bilsteins (black) in front and I rarely notice how stiff the car is except when I turn the wheel. The few times I have been on dirt roads though, it is very noticeable and about as bad as my lowered Nissan truck. It is a lot worse than my Prius C, a car with only about 2 inches longer wheelbase but a suspension more tuned for comfort than fun.
Old Jun 19, 2019 | 08:53 AM
AngryScotsman's Avatar
AngryScotsman
Nothing an AAA membership can't fix.
Or carry an air pump and some tire sealant. It'll be enough to get you a few miles to a tire shop where they'll curse while having to fix the tire with the innards covered in the tire sealant. :D
Old Jun 19, 2019 | 08:58 AM
alconk's Avatar
alconk
Yep I second that.
Old Jun 19, 2019 | 06:10 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Which Bilsteins did you install? We've not had good luck with them for ride improvement or even for performance. Their Coilovers have been good, but that is a differen ballpark.
Old Jun 19, 2019 | 07:41 PM
alconk's Avatar
alconk
I bought the B4s. I just went and changed the run flat tires to something different and ride is much better now. By the way you have any coupons available? I want to order a ATI damper but wow expensive..
Old Jun 20, 2019 | 10:38 AM
Zsm's Avatar
Zsm
The B4s get better over time.
Initial 500-1000 miles are a bit harsh, but then smooths out as the struts break in.
Old Jun 20, 2019 | 11:18 AM
alconk's Avatar
alconk
Great! thanks!
Old Jun 20, 2019 | 02:00 PM
Yep, the b4 are a good for daily but the ride is not as smooth as the KONI REds /FSD
phantasms
Factory JCW Talk (2009+)
27
Sep 19, 2010 08:33 PM
Black Boots
Jan 2, 2010 12:51 PM
Blazermaniac
Sep 24, 2007 01:17 PM
jeremy99
Feb 1, 2003 03:53 PM
