R50/53 R53 oil leak?
Old Jun 9, 2019 | 07:00 PM
alconk's Avatar
alconk
R53 oil leak?
Ok I thought I had the same ol oil leaks that these cars are notorious for ( crank sensor o-ring, valve cover and oil pan gasket) which all have been replaced recently but still spots on the drive so back under the car I go. The last gasket I replaced was the oil pan and was last weekend and while the pan was down I cleaned everything very through but noticed an opening to the transmission. I sprayed brake cleaner and had lots of grime flowing out of it and was really hoping the rear main seal isn’t leaking. Well like I say I still have spots on the driveway and the very lowest bolt head has the oil on it right where the engine and trans bolt together so is it most likely the rear main seal? That will b a huge job since the trans has to come out but I read on here that if you have a failed rear main seal your clutch would slip which it does not. Ideas??
Old Jun 10, 2019 | 09:25 AM
gumbedamit's Avatar
gumbedamit
Oil Cooler gaskets
Oil Filter gasket
Dip Stick O-ring
Timing Chain Guide O-rings
Front Main Seal
Yeah, these cars leak like they have Swiss cheese for gaskets. May the Force be with you....
Old Jun 10, 2019 | 09:54 AM
alconk's Avatar
alconk
Originally Posted by gumbedamit
Oil Cooler gaskets
Oil Filter gasket
Dip Stick O-ring
Front Main Seal
Lol all of those items are fine just concerned where the block meets the trans
Old Jun 10, 2019 | 10:46 AM
Tgriffithjr's Avatar
Tgriffithjr
Clean everything well and the run it. Get under and look for where the highest set spot is. Your leak will originate somewhere in that area. I don’t agree that they leak like Swiss cheese. I have 81000 miles and no leaks other than the power steering low pressure hose that leaked at the tank. Fixed that with a screw hose clamp.
Old Jun 10, 2019 | 11:08 AM
gumbedamit's Avatar
gumbedamit
Good thing about being here, Everyone is entitled to their own opinion; However, These cars are NOTORIOUS for leaking, count yourself lucky if you've not experienced this problem.... thus the reason the OP is asking the question after all the other PROBLEM spots have been taken care of
Old Jun 10, 2019 | 01:20 PM
Tgriffithjr
[size=3] Everyone has different experiences. I’m sure I’m not the only person who has not had leaks. Some do and some don’t. Maybe the only people we hear from are primarily those who have issues. If you don’t have problems you are less likely to comment on here.[/size]
Old Jun 10, 2019 | 01:38 PM
alconk's Avatar
alconk
Yep very true
Old Jun 11, 2019 | 06:22 AM
gumbedamit's Avatar
gumbedamit
Yep very true
Not saying that everyone has leaks, stating that these cars are Notorious for their leaks. Just like the PS pumps on these cars are problematic, I've not had this problem, but it still exists. As popular as NAM is, I'm certain that not Every One that owns a Mini is a member. Nothing is absolute Denying a known problem doesn't make it go away. Good luck with figuring out what your leak is.
Old Jun 18, 2019 | 10:30 PM
alconk's Avatar
alconk
Well I found out where the oil leak is coming from and it's not oil but trans oil. It's leaking from the clutch release rod bushing but now will have to figure out how to replace it. I will post a different topic for that.
Old Jun 19, 2019 | 04:06 AM
RudeJoe's Avatar
RudeJoe
...I sprayed brake cleaner and had lots of grime flowing out of it and was really hoping the rear main seal isn’t leaking
The grime was at least in part the dust from the clutch and flywheel. When I changed out my clutch the interior of the bell housing was coated with a black soot. Your brake cleaner liberated that soot. I took pictures when I changed out the clutch on my Mini, if I can find them I'll post them this evening.
Based on your other posts you might still have an oil leak from the rear main seal or the front transmission seal.
Old Jun 19, 2019 | 05:38 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Even a badly rear main seal will unlikely cause the clutch to slip. The oil is blocked by the front of the flywheel and centrifugal force will fling the oil onto the bell housing then leak out via the "drain hole". The remaining coating on the bell housing help clean the dust off the environment like how K&N filter works.
You symptom is consistent a harden thus leaking rear main seal. What is th mileage of the engine?
All ICE engine leak oil sooner or later. Typically proportional to the milage of the engine. Think cumulative heat and time - like the area under the temperature time curve of the engine parts.
Old Jun 19, 2019 | 08:41 AM
alconk's Avatar
alconk
Car has 136k on it. I was looking at pictures last night on how to replace that bushing and I gathered there is no oil or fluids in that area. Sorry never had one apart. So are you saying the flywheel is flinging oil from the rear main up to the bushing and leaking out of it then?
Old Jun 19, 2019 | 08:43 AM
pnwR53S's Avatar
pnwR53S
I cannot debug your problem remotely for you. I am just giving you some fruits for thought. Successful diagnose ultimately depends on you.
Old Jun 19, 2019 | 08:57 AM
alconk's Avatar
alconk
Sure I understand and greatly appreciate any thoughts or options that is why I come here.
Old Jun 20, 2019 | 02:00 PM
Got pics of the leak?
Old Jun 20, 2019 | 02:10 PM
alconk's Avatar
alconk
I will get some.
Old Jun 20, 2019 | 02:12 PM
Ok thanks
Old Jun 20, 2019 | 02:13 PM
alconk's Avatar
alconk
Ok thanks
No thank you I appreciate your concern
quikdime
Jul 5, 2019 10:17 PM
vhsnap
Sep 3, 2017 04:24 PM
DRoc7822
Feb 15, 2016 12:47 PM
Marwan
Apr 23, 2011 08:29 AM
22CooperS
Nov 27, 2007 08:12 PM
