R50/53 R53 rear washer reservoir ?
Old Feb 5, 2019 | 06:42 PM
NomadMac's Avatar
NomadMac
Is there a separate reservoir for the rear windshield washer or is it fed by the one under the hood?
I can hear the pump working in the rear but there is no spray.
Clogged nozzle?
Old Feb 5, 2019 | 06:49 PM
MC40Russ's Avatar
MC40Russ
Clogged nozzle?
Mine has the same issue....I haven't spent the time to see if the hose is clogged or disconnected... I don't know where to even look.
Old Feb 5, 2019 | 08:26 PM
H_C's Avatar
H_C
https://www.carcarekiosk.com/video/2...luid/add_fluid
Old Feb 5, 2019 | 08:36 PM
NomadMac's Avatar
NomadMac
Thanks for the link.
It didn't answer any of my queries, though.
Old Feb 5, 2019 | 09:04 PM
AoxoMoxoA's Avatar
AoxoMoxoA
Rear is fed by the reservoir on the front/right side of car. Front left is for headlamp washer if applicable. There’s only a single pump which can pump in both directions for both front and rear washing. It reverses polarity depending on where you choose to wash.
Assuming there’s washer fluid in the reservoir, then yes, a clogged nozzle is a possibility. It’s a fairly common issue remedied by removing the rear wiper arm and inserting (with fingers) a drill bit (3/32” maybe, 1/16”? I forget... the biggest that will fit into the hole) into the metal fluid outlet fitting and spinning clockwise (again, with fingers) to clear the clog.
Old Feb 6, 2019 | 07:11 AM
MINI33342's Avatar
MINI33342
Clogged sprayer. I have to change mine out every couple of years. It is the small plastic part that covers the connection for the arm to nozzle.
Old Feb 6, 2019 | 07:19 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Watch THIS video from 4:09 onward for a reference to my post above...
I didn't go the power drill route, and was able to clear the clog (likely corrosion) with finger power alone.
Old Feb 6, 2019 | 09:59 AM
rwkeating's Avatar
rwkeating
Did you verify that no washer fluid was coming out? From the drivers seat I saw no washer fluid was squirting on the window but I heard the pump run and knew the reservoir was full. Upon further investigation I found the rear nozzle was not lined up properly. It was squirting into the under side of the wiper blade arm cover. Pulling it out a bit and realigning it fixed the problem.
Old Feb 6, 2019 | 10:29 AM
JAB 67's Avatar
JAB 67
I followed this procedure today and it worked perfectly. Thanks.!
Old Feb 9, 2019 | 10:43 AM
NomadMac's Avatar
NomadMac
Tried the drill out. Didn't work for me.
Any suggestions for a next step?
Rear panel removal?
Blow air up the fitting?
Old Feb 9, 2019 | 11:08 AM
JAB 67's Avatar
JAB 67
Nomad: How far did you try to insert your drill? Mine required more than I expected, but it worked. I would say somewhere between an inch and an inch and a half.
Old Feb 9, 2019 | 12:33 PM
NomadMac's Avatar
NomadMac
I went through the soft material until I got to be what seemed solid and probably the back of the elbow.
In other words, probably an inch and a half.
Thanks,
Martin
georgeUSC
Jun 26, 2018 02:15 PM
SKL
Sep 21, 2007 05:21 PM
lindros2
14
Dec 7, 2006 01:07 PM
jtpryan
Jun 25, 2004 06:19 AM
crashgearbox
Feb 13, 2003 04:24 PM
