Just bled the brakes and want to bleed the clutch slave cylinder on my '03 MCS- does it use the brake reservoir or is there a small separate one I can't find??
TIA...
(BTW, just joined so guess I'm welcoming myself with a new post- search didn't turn up this answer...)
TIA...
Clutch slave uses fluid from the brake master. It's a PITA to bleed. If the clutch is working OK, don't bother.
Jim
Just bled it- easy to get at after removing the front splash panel. Much easier to access than my spec Miata race car! Love the Motive pressure bleeder too!
