R50/53 oil gauge
Old Sep 22, 2018 | 10:54 AM
jk6672's Avatar
jk6672
oil gauge
Are these factory installed gauges?
The oil temp gauge isn't working and I assume it's a faulty oil temp sensor. Where is the oil temp sensor located?
Old Sep 22, 2018 | 03:50 PM
A383Wing's Avatar
A383Wing
Yes, extremely rare item
Old Sep 22, 2018 | 04:31 PM
OCR's Avatar
OCR
"Possibly..!"
Yes the factory did install them.
If you watch, you can buy them here on this site (I think there's a set for sale now) and on E-Bay. So that means, that they aren't necessarily..."factory" installed.
Mike
Old Sep 22, 2018 | 05:16 PM
jk6672's Avatar
jk6672
regardless though, does anyone know where I can look for the sensor and where to buy another one if it's faulty?
Old Sep 23, 2018 | 05:43 AM
AoxoMoxoA's Avatar
AoxoMoxoA
On vehicles equipped with the oil temperature gauge, the sensor (p/n 82940004581) doubles as the oil drain plug at rear of pan. There’s a wire that connects to it.
Old Sep 23, 2018 | 07:12 AM
Super Coop's Avatar
Super Coop
IIRC these were installed at the factory on the MC40. They were a dealer option or available as an OEM accessory. I've got them on my car and will remove them if I ever sell it to buy a GP. They're that rare.
Old Sep 23, 2018 | 07:27 AM
Goldsmithy's Avatar
Goldsmithy
MINI Alliance Ambassador
Those are standard VDO gauges. I would question if they were the original gauges as they have black faces instead of a white/cream face. Doesn't matter as VDO makes very good gauges. They are very easy to install, all it takes is the proper sending unit.
Old Sep 23, 2018 | 07:49 AM
ItsmeWayne's Avatar
ItsmeWayne
Yes, it is the drain plug sending unit!
Old Sep 23, 2018 | 08:56 AM
Paul's Avatar
Paul
There was a color change for the gauges at some point. In 2008 the silver were discontinued with black gauges remaining available. Realoem has details.
Old Sep 23, 2018 | 09:31 AM
jk6672's Avatar
jk6672
Thanks guys, I’ll check the oil plug. BTW, they are the same color as the speedo. Bad photo I guess, but they for sure aren’t black.
Old Sep 23, 2018 | 09:32 AM
jk6672's Avatar
jk6672
thanks. With this knowledge I hope they either forgot to plug it back on after an oil change.
Old Sep 23, 2018 | 09:36 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Easy enough to check!
Also possible is that it’s not even there anymore.
Old Sep 23, 2018 | 02:36 PM
jk6672's Avatar
jk6672
Well I was able to take a sec and get under the car to see. It just has a regular oil plug installed. I did see what looked like shrink tube with maybe some wire in it. I'll investigate later on a day off. I did however notice I probably have a slight leak on the power steering hose I need to remedy
Old Sep 24, 2018 | 07:26 AM
Yes, Looks like they removed the sensor and thats why you have oil temp function. I would check the wires going from the unit and see if you can find them, if not or if they are somewhat there, you might have to make your own wires to feed to that sensor. Get the sensor from us and then make wires to fit.
My guess is someone had a leak or forgot the sensor and they just took it out.
https://www.northamericanmotoring.co...-and-leak.html
Dont forget that crush washer'.
Old Sep 24, 2018 | 09:04 AM
RedAggie03's Avatar
RedAggie03
Be prepared there's probably a reason they removed the sensor. They had very short threads and caused the oil pan plug threads to get stripped out. So that might have happened and they put the longer factory style plug back in. That was the case with mine and it was so bad that I had to re-tap the drain plug up a size to a M16. I decided to drill and tap a separate hole for the sensor and I would consider that if you're handy. I also had a power steering pump hose leak and it's a good time to remove all of that and replace the hoses...it gives you the clearance you need to retap the pan if you need.
You can see some photos in my build thread starting at post #100...
Also, as a note so you don't get confused, I took the uber rare center console gauges and installed them in the uber rare steering column gauge pod... uber uber rare :P
Good luck.
Old Sep 24, 2018 | 01:06 PM
AoxoMoxoA's Avatar
AoxoMoxoA
I did however notice I probably have a slight leak on the power steering hose I need to remedy.
You may qualify for the factory recall on the p/s pump & fan on your MINI.
It's been reported that if the associated p/s hoses are leaking, MINI will replace those as well.
Click HERE and enter your VIN to check your vehicle.
Read about the recall HERE & HERE.
Old Sep 26, 2018 | 12:42 PM
jk6672's Avatar
jk6672
it came with the maintenance records, PSP was replaced. I double checked the recalls on the link you posted too.
Old Nov 11, 2020 | 03:42 PM
40mini's Avatar
40mini
I am new to the site, so apologize if there is an easier way to find this information.
I cant find the oil temp sensor 82940004581 anywhere. Any one know where I can pick one up? Is there an equivalent to it?
Old Nov 12, 2020 | 09:27 PM
jk6672's Avatar
jk6672
That sucks, your correct. I just checked where I bought mine and it’s no longer available. If you know the bolt size, thread pitch, maybe you can match something up. I just looked on Amazon for oil temp sensor and there were a few that look promising as a replacement.
Old Nov 13, 2020 | 09:06 AM
cooper48's Avatar
cooper48
Do I have a treat for you guys! I looked for these for a couple of years. Search eBay for:
Temperature Sensor NTC Motor Oil VDO A2C1754920001
These are manufactured in Latvia (VDO no longer makes them) so it takes a while to get one ($23 + shipping) but it is the correct part. I ordered one for my MC40 and it works perfectly.
Old Nov 13, 2020 | 04:25 PM
Jonny's Avatar
Jonny
Thanks so much for that link. I scored one of the gauge pods for $75. How about a link to the wiring kit and chrome bezels lol. Looks like it’s out of stock. He’s on vacation until the 16th. Hopefully it can still be ordered when he gets back.
Old Dec 6, 2024 | 09:32 AM
noodlesandsam's Avatar
noodlesandsam
I just got one of the last 2 on that link. TYVM
Old Dec 6, 2024 | 02:02 PM
We now got some options since the Genuine MINI on went nla, even got the VDO version https://www.ecstuning.com/Search/Sit...h/82940004581/
Old Dec 6, 2024 | 10:41 PM
noodlesandsam
Thanks for the link. I tried your site - could not
find the VDO.
Old Dec 9, 2024 | 08:14 AM
Yep, search by Oem MINI part number or by brand "shop by brand" as we have so much on our site for MINI, sometime things get lost in the search.
Poppa Bear
Electrical
May 4, 2010 04:26 AM
kriation
15
May 17, 2008 09:41 AM
#20Works4me
Jun 18, 2007 03:52 PM
TonyB
Sep 11, 2006 04:28 PM
