R50/53 R53 Front grab handles?
Old Jul 5, 2018 | 01:54 PM
Derek Jones's Avatar
Derek Jones
So, to save some money on my '03 MCS, I removed the headliner board myself and dropped it off at the upholsterer.
Worked out great, but they left 2 holes on each side in the front for what I can only assume are for grab handles. But I'm pretty certain I didn't remove any. (I say pretty certain because this car has been a project, so decent time lapse between items.
Doing a search, a diagram did seem to indicate some handles available.
However, I don't see any attachment points behind the holes.
Anyone have any insights? Do you have front handles? Attached to....?
Tia
Old Jul 6, 2018 | 03:12 PM
audihere's Avatar
audihere
My '05 has one grab handle on the front passenger side (similar to rear grab handles) and a second visor mounted on the driver's side in that position.
Old Jul 8, 2018 | 04:51 PM
DamnCampers's Avatar
DamnCampers
Pre facelift there was only grab handles in the rear. Facelift cars have the passanger grab handle and extra driver's visor.
Old Aug 8, 2019 | 07:59 PM
Derek Jones
Reviving this question
Okay, so I could add a grab handle to the passenger side, and a visor to the driver's.
The question is, how to anchor them. The rear handles have screw holes right behind the cutouts. In the front, it appears that there are only square holes near the roof. C-clips? Some other nut?
Old Aug 8, 2019 | 08:26 PM
DamnCampers
The rear should be a matter of placing the holes in the headliner. The extra visor on the drivers side could be done with a clip to accept the screw. Be sure it doesn't interfere with the side curtain airbag as they run along the edge.
Old Aug 8, 2019 | 09:25 PM
Derek Jones
Rear isn't a problem. Those handles are already back in.
I'm hoping someone can tell me what clip for the front. Like, what is used in the 05?
My guess is that since they modified the airbag, it's going to be a bad idea for me to try this.
Old Aug 9, 2019 | 12:42 AM
DamnCampers
As I'm not sure as my mini is a pre-facelift I can't look and see. I doubt they would make changes to the airbag to accommodate a handle. If you look here https://www.realoem.com/bmw/enUS/sho...diagId=51_5575 I believe you just need the part labeled as #8.
Old Aug 9, 2019 | 09:38 AM
Husky44's Avatar
Husky44
Just installed my 06 headliner two days ago. Both the grab bar and DS visor install with sheet metal screws that thread straight into holes in the body panel. No clips.
Old Aug 9, 2019 | 10:52 AM
Derek Jones
Thanks for the response. Unfortunately, the earlier models weren't built that way. There are no screw holes. Only rectangular somewhat large (~1"x.5") holes that are behind the side airbag channel.
Old Aug 9, 2019 | 12:44 PM
Husky44's Avatar
Husky44
Sorry, I got confused while reading previous replies and thought yours was an 05.
I'd be cautious about installing a grab handle using clips, particularly on the passenger side, as someone might put some weight on it and rip it loose. The only extra visor should be OK mounting with clips.
Old Aug 9, 2019 | 12:48 PM
Derek Jones
Good point! Thanks!
Nicefeet
Jan 23, 2016 04:09 PM
joe_r
Want to Buy - All Other Items (archive)
14
Jul 6, 2008 02:02 PM
snid
16
Dec 10, 2007 11:28 AM
resmini
Sep 28, 2005 04:27 PM
gnhovis
Tires, Wheels, & Brakes
Jul 21, 2005 05:04 AM
