R50/53 Help Identifying Mystery Part
Old May 14, 2017 | 01:51 PM
ericfreeman's Avatar
ericfreeman
Help! For several months I've had the front subframe, trans, etc. out of my 2004 Cooper S and now that I'm reassembling the car I've found a part I can't identify. I've been through all the parts diagrams on RealBMW.com but can't find this piece. It's a blue plastic piece, curved a bit. Here's a pic.
Thanks in advance for any help.
Eric
Old May 15, 2017 | 06:53 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Originally Posted by ericfreeman
...I've had the front subframe, trans, etc. out of my 2004 Cooper S and now that I'm reassembling the car I've found a part I can't identify...
Part of a Makita impact wrench used to disassemble subframe?
Sorry, but no clue whatsoever...
Old May 15, 2017 | 08:28 AM
Yea, thats my guess. Its looks like the color of the ABS sensor and plugs but I dont see anything close to that shape.
Old May 15, 2017 | 12:56 PM
ericfreeman
Thanks guys. I guess the part is from one of my other projects that just happened to get onto the bench with the Mini parts. I'll keep my eye out as I finish the assembly to see if there's anywhere it can fit.
Eric
Old May 15, 2017 | 01:05 PM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
Is that the factory insert for a transmission mount?
Old May 15, 2017 | 01:38 PM
AoxoMoxoA's Avatar
AoxoMoxoA
Good work... I believe you are correct!
You get the Grand Prize!
Old May 15, 2017 | 01:39 PM
Bravo!
Old May 15, 2017 | 01:46 PM
Yellowducman's Avatar
Yellowducman
I have the same piece after my clutch job. Does anyone have a diagram where said piece goes. I know it came out of the trans mount but can't figure where it goes.
Old May 15, 2017 | 01:47 PM
Yellowducman
I see it in the pick now.
Old May 15, 2017 | 02:19 PM
sarom058's Avatar
sarom058
OH MY GOD MY DREAMS HAVE COME TRUE!!! I CAN DIE HAPPY NOW
(assuming I actually manage to fix my accursed Mini before my untimely death, lol)
Old May 16, 2017 | 07:51 PM
ericfreeman
Thanks for finding that part! But, ****, now I have to figure how to get it back in place! Unfortunately, I have everything back together. Might have to leave this part out for now.
Eric
Old May 18, 2017 | 02:40 PM
sarom058's Avatar
sarom058
Remove the mount and press it in! Spray a little lithium grease or something if the rubber is too deformed from wear/tear. Don't forget that you can also opt for the awesome polyurethane gearbox insert that Way sells! I highly recommend
Old May 18, 2017 | 05:56 PM
ericfreeman
Removing the mount wasn't an option at this point: everything was back together. I found that I could remove the lower engine brace and with a few air hoses removed lower the trans end enough to expose the bottom of the mount. It was easy to slip the plastic shim back into place.
Eric
