R50/53 Well, She's back on the road.
Old Dec 30, 2016 | 03:52 PM
traildog's Avatar
traildog
I sure am glad I found this site!!! Thanks for all the help......
New shocks and struts, 2 new axles, oil pan gasket, SC oil service, new hoses and seals for the cooling system, shock tower braces.
I'm beat, sore and satisfied........
Now, I'm heading back out to tackle that seat latch......
Old Dec 30, 2016 | 04:39 PM
Bernard Barbour's Avatar
Bernard Barbour
Way to go Sir! Also working on my 2004 R53 with 160,000 miles, tackling many of the same items. Keep up the great work and post up a few photo's of your project and completion. Cheers!
Old Dec 30, 2016 | 07:42 PM
Andrew Riley's Avatar
Andrew Riley
Great to hear man, keep up the good work, keep motoring on!
How long the S/C service take you?
Old Dec 31, 2016 | 02:24 AM
traildog's Avatar
traildog
Thanks.
It's really hard to say how long it took. I disassembled the car, probably 2 hours or so, waited for the required parts, and reassembled. Probably another 2 hours or so.
Old Dec 31, 2016 | 11:26 AM
Shawnnn's Avatar
Shawnnn
Great feeling getting everything fixed and doing all the work yourself.
Was the sc low on oil?
Old Dec 31, 2016 | 01:08 PM
traildog's Avatar
traildog
I would say that I got quite a bit out of it. I posted pictures of the amount somewhere on here. Here it is. https://www.northamericanmotoring.co...ml#post4262191
I must say though, my celebration was a bit premature...........
I found about 2 tablespoons of coolant under the car this morning.....
Any leaking is too much for me so...... back apart she comes. Seems like every time I fix one leak, another one pops up......
Old Jan 2, 2017 | 01:14 AM
Mini Mania's Avatar
R53
Let us know what you find!
Old Jan 2, 2017 | 03:23 AM
sherman89's Avatar
sherman89
It is possible that the coolant lines off the exchanger did not like being disturbed when you did the axle work or you did not get all the clamps tight on the new coolant hoses.
Old Jan 2, 2017 | 04:24 PM
traildog's Avatar
traildog
Just added a small amount of dye and I'll be checking it in the morning.....
Old Jan 2, 2017 | 05:11 PM
traildog's Avatar
traildog
So far, I can see it running down the front of the engine coming from above the crank sensor.
Old Jan 3, 2017 | 03:09 AM
sherman89's Avatar
sherman89
That is a long way from the heat exchanger, it must be related to a hose/seal change.
Old Jan 3, 2017 | 03:14 AM
JAB 67's Avatar
JAB 67
That would be the flange that connects the water pump to the engine block.
Old Jan 3, 2017 | 06:56 AM
traildog's Avatar
traildog
I was afraid of that and I just changed it and both seals because it was leaking there before....
Old Jan 3, 2017 | 03:55 PM
traildog's Avatar
traildog
Got her apart tonight. Puddle of coolant under the water pump flange but no evidence of die I put in the system..... I'm stumped......
Old Jan 5, 2017 | 05:38 PM
MiniMello's Avatar
MiniMello
did you run it long enough with the dye for the thermostat to open and circulate it properly i know on my car it takes a long time at idle for the thermostat to open and circulate it thoroughly , that might be why the dye didnt get that far
Old Jan 6, 2017 | 03:11 AM
traildog's Avatar
traildog
Oh yea, I drove it 20 miles.....
