R50/53 Lower Motor Mount Suggestions
Old Jan 3, 2017 | 12:36 PM
Andrew Riley's Avatar
Andrew Riley
Torque Solutions - From ECS
I think it's time to get rid of some of the play on the engine. Has anyone tried the Torque listed above? Car has 120k on the clock, so I'd like to think I got the best out of my original.
Any suggestions?
Old Jan 3, 2017 | 01:00 PM
sherman89's Avatar
sherman89
With the poly mount I suspect that you will get vibration into the interior of the car especially at the wheel----unless you are looking for max performance I personally would stick to stock which is what I did last month when I changed all the motor mounts. Check out Lemforder at Pelican---that is where I got my mounts. Lemforder is a OEM for BMW.
Old Jan 3, 2017 | 01:17 PM
X757XVeritas's Avatar
X757XVeritas
If you are a do it yourselfer here's a cheap alternative. Did all mine (I wrote the how to) and they are still holding up perfect! I really didn't notice any increase in vibration, and the car feels much more responsive.
Woops forgot the link!!
https://www.northamericanmotoring.co...or-mounts.html
Old Jan 3, 2017 | 06:10 PM
Andrew Riley
That's interesting for you and the DIY? How did you come about this "experiment"?
Unfortunately I don't have a week of downtime right now. Beginning of the year and business starts to ramp up...
So solid > poly for the use of DD, weekend runs through the twisties, and occasional AutoX?
Old Jan 3, 2017 | 07:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We find those and the BSH mount to be too hard for most as the small end is solid.
So I would suggest just going with a stock mount and adding the powerflex inserts.
https://www.waymotorworks.com/oem-mi...t-r50-r53.html
https://www.waymotorworks.com/powerf...ng-insert.html
Or we now offer stock lower brackets rebuilt with new powerflex complete bushing replacements installed. And if you think it is too hard the center black insert is removable to soften it up.
https://www.waymotorworks.com/powerf...-assembly.html
Old Jan 3, 2017 | 09:30 PM
X757XVeritas
I've done this on a bunch of different vehicles I've owned. It's an old trick. It started with people doing this to repair cracked and seperated rubber mounts on the cheap. And someone noticed that it hardens to the same thickness as the inserts and gave a little more rigidity. Hardens to the same consistency as the inserts but you have to have patients and not care so much about how it looks. I didn't really care. I'm not trying to win any awards for looks lol.
I was gonna go with the inserts, which are much easier and faster to do, but I'm a tightwad sometimes. There has to be good reason to spend the extra money for me. And I just didn't see any pros for the inserts that outweighed the con of these not be so pretty but doing the same thing for a lot less.
I bought all new oem mounts and a tube of the stuff for less than all the inserts would have cost me.
Old Jan 6, 2017 | 10:08 AM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
Woah, Veritas, I didn't realize you were the one who thought of the DIY poly mounts!
My last R53, Sunflower, was rocking a polyurethane-caulking-filled upper mount, thanks to you!!! I added a small modification of smoothing the urethane before drying, and then plastidipping the brown urethane black, and peeling the metal body of the mount once it dried for a "OEM" black-mount, metal-casing look. Thanks!!!
It may rattle your dash out, but it drives sooooooo much better than factory!!! The way I see it, most performance mods add some vibration and additional forces to the mounts, so you might as well mount the most important bits of the car into the car as firmly as possible. Plus, with the TSW passenger mount, the BSH lower mount, and the Powerflex gearbox mount that Way sells, you can basically guarantee that you never have to worry about damaging something while shifting ever again.
Old Jan 6, 2017 | 10:15 AM
X757XVeritas
Your welcome lol. I didn't really care how mine looked just how it performed!
