Fill plugs on supercharger.
Old Dec 1, 2016 | 01:59 PM
traildog's Avatar
traildog
I'm dying open them and see if there's any oil on it before I swap it out with a rebuilt one......BUT the plugs are stuck......would heating them with a torch hurt anything?
Any other suggestions on how to get them out?
I mean they are STUCK.........
Old Dec 1, 2016 | 02:34 PM
traildog's Avatar
traildog
Extractor got the pulley side one and look how much oil.was in it....
Old Dec 1, 2016 | 03:10 PM
traildog's Avatar
traildog
Got the pto side out....not much oil in there...
Old Dec 1, 2016 | 03:17 PM
traildog's Avatar
traildog
Can anyone tell me where to get two oil fill plugs for my supercharger? I really butchered The Originals up
Old Dec 1, 2016 | 03:37 PM
JAB 67's Avatar
JAB 67
Thats probably not too bad for the pulley side; capacity is 4.9 oz. PTO side is 1.4 oz; how much did you get? And how many miles on your s/c?
Old Dec 1, 2016 | 05:53 PM
traildog's Avatar
traildog
200k on the SC.
I'd say less than 1oz.
Old Dec 3, 2016 | 05:08 AM
traildog's Avatar
traildog
Man, finding these fill plugs is like looking for a needle in a haystack.....
Anyone?
Old Dec 3, 2016 | 02:54 PM
R6boater's Avatar
R6boater
Have you check local hardware stores in their specialty fastener section? Or tried contacting Eaton?
Old Dec 3, 2016 | 05:35 PM
traildog's Avatar
traildog
Haven't talked to Eaton yet but, I went to a local hardware. Their fastener section is the biggest I've ever seen........ no luck.....
Old Dec 3, 2016 | 07:34 PM
R6boater's Avatar
R6boater
If you search here, there are directions on installing a dipstick setup on the PTO end. That would eliminate the need for one of the plugs. In that post it also tells you what the thread pitch is, may help you track down what you need. Oh, check grainger and mcmaster-carr.
Old Dec 3, 2016 | 09:03 PM
traildog's Avatar
traildog
Thanks, I'll take a look.
Old Dec 5, 2016 | 08:01 PM
Mini_Crazy's Avatar
Mini_Crazy
Anyone?
Here's a source for magnetic drain plugs for the supercharger. They are pricey, but the magnet for the water pump gear drive end seems like a good idea:
http://www.drainplugmagnets.com/minicooper.php
Old Dec 5, 2016 | 08:17 PM
JAB 67's Avatar
JAB 67
That says 'Roots' supercharger; are Roots and Eaton interchangeable?
Old Dec 5, 2016 | 08:26 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We offer magnetic plugs for the supercharger
https://www.waymotorworks.com/magnet...-cooper-s.html
Old Dec 5, 2016 | 09:07 PM
Mini_Crazy's Avatar
Mini_Crazy
"Roots" is a two-scroll design-type of supercharger. Eaton is a manufacturer of Roots design superchargers.
https://en.wikipedia.org/wiki/Roots-type_supercharger
(The GMC 6-71 & 8-71 superchargers used on diesel engines and Top Fuel dragsters are also of a Roots design.)
Old Dec 5, 2016 | 09:43 PM
Mini_Crazy's Avatar
Mini_Crazy
Anyone?
Here is a low-cost source for non-magnetic plugs that should be the correct type of O-ring pressure seal to work properly. At $3/each, it would be worth buying them to compare with the buggered ones you removed:
http://www.ebay.com/itm/NEW-SAE-Plug...-/252114262122
Old Dec 5, 2016 | 11:11 PM
MiniKar's Avatar
MiniKar
Just call Way Motor Works ! He will take care of what you need ! ! !
Old Dec 6, 2016 | 04:51 AM
traildog's Avatar
traildog
I saw the magnetic ones and the ones I can buy from Germany and China.
I ended up filling the plugs I have with................JB WELD and then I cut a nice screwdriver slot in them.....
Anyone know the torque setting for these plugs?
