R50/53 Glove box latch not holding
Old Sep 6, 2016 | 02:37 PM
lamontcg's Avatar
lamontcg
So the latch on my 2003 "S" glovebox no longer holds the glove compartment door up (closed). It does not appear to be adjustable -- and I've never seen that to the be the case on any other car I've owned. Curious if anyone else has had this issue?... and if so, if they came up with a solution. Please, no kidding about duck tape -- sadly enough, I finally resorted to that.
Old Sep 6, 2016 | 08:31 PM
Filmy's Avatar
Filmy
I had problems with that after removing the glove box for my audio install. I fixed it by tightening/adjusting the screws that actually mount the entire glove box - I think it was the top screws that did the trick. You may have to put washers/spacers in-between the box lip and the screw holes to get it just right.
Old Sep 7, 2016 | 04:52 AM
mcb66's Avatar
mcb66
I used velcro and super glue. Seems to work fine.
Old Sep 7, 2016 | 12:04 PM
IQRaceworks's Avatar
IQRaceworks
I pulled the latch out of mine, and spaced it a little "deeper" with a few small washers. Now the latch engages farther into the little ledge, and holds the glove box closed nice and tight. Before it would just fall open at random times......because the little latch was just barely catching on the ledge.
It makes sense if you take a look at it up close.
Old Sep 7, 2016 | 01:37 PM
Kaniyrret's Avatar
Kaniyrret
I had to replace the one on my 2003, box and all!
Old Sep 7, 2016 | 02:04 PM
https://www.northamericanmotoring.co...ox-handle.html
For the glove box handle issues.
And for the latch side.
https://www.northamericanmotoring.co...e-ordered.html
Old Sep 7, 2016 | 04:27 PM
03cooperr53's Avatar
03cooperr53
The same here. Velcro along the top and side. I used a heavy duty staple gun to staple the velcro to the inside of the glove box.
Old Sep 7, 2016 | 04:33 PM
xsmini's Avatar
xsmini
I just pulled mine, parcel shelf now
Nik
Bshade
Apr 29, 2016 02:12 PM
Juanfe
Apr 25, 2016 12:31 PM
brawsie
Mar 27, 2016 12:25 PM
ApexinM3
Mar 25, 2016 12:21 PM
VerucaSalt
40
Nov 10, 2005 11:50 AM
