R50/53 Antifreeze leak/overflow help
Old Mar 11, 2016 | 11:46 AM
Morganinaboat's Avatar
Morganinaboat
What causes the radiator fluid/antifreeze to overflow out of the reservoir after running the car? Engine was not overheating - OEM temp gauge shows just slightly below halfway mark. Supplemental cooling fan did kick on and was running when I got out and I noticed fluid leaking steadily. Fluid was that spendy Pentosin stuff. Was steaming/flowing out from the cap on the new aluminum coolant reservoir tank. About to be done with this car. Love it and am now hating it. Suggestions?
Old Mar 11, 2016 | 12:47 PM
AoxoMoxoA's Avatar
AoxoMoxoA
Too much coolant in system?
Old Mar 11, 2016 | 12:56 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Did you put a new cap on when you got the tank or reuse the old one? I'd check the cap and make sure it's not in poor condition.
888.280.7799 | 6am - 5pm PST
Old Mar 11, 2016 | 02:57 PM
Morganinaboat
Reused it. Because I'm either cheap or broke after all the $$ i've spent on the Tardis in the last six months.
Old Mar 11, 2016 | 03:29 PM
PelicanParts.com
Vendor
Check and make sure the seal on the cap isn't bad. It's also good, as mentioned above, to make sure there isn't too much coolant in the system.
https://www.northamericanmotoring.co...erflowing.html
https://www.northamericanmotoring.co...-overflaw.html
Old Mar 11, 2016 | 04:29 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Have patience. On the aluminum recovery tanks, (Forge, Canton, etc.) you want coolant only about 1 inch above the bottom when cold. Use a piece of wooden dowel to check. Then go buy yourself a higher rated pressure cap...22-24 Pounds.
Old Mar 15, 2016 | 09:18 AM
Vkng's Avatar
Vkng
When that was happening to me it was a bad thermostat. Temperature was normal both on the gauge and via obd, but it was still bubbling over. I have the Forge tank too.
Old Mar 15, 2016 | 10:25 AM
bansasn's Avatar
bansasn
Your not alone. Just bought a new aluminum tank this weekend. I have the same symptom as you now. I have a new OEM cap and my old one. Looks like my new cap isn't much better than my old OEM cap. Still, the fluid is doing the same thing as yours. Also new water pump, housing, and thermostat.
Old Mar 15, 2016 | 11:50 AM
Morganinaboat
Thanks Trackrat. I will check that coolant level as you suggest. I think it may have just be too full and released the excess. I do hate that I cannot see the level in the container without opening the cap but such is life. Thanks again.
armydad77632
Apr 19, 2017 09:19 AM
thebombardier
Tires, Wheels, & Brakes
14
Mar 10, 2016 02:57 PM
Calyman24
Mar 7, 2016 09:27 AM
Gizmotech
Mar 5, 2016 07:00 AM
PelicanParts.com
Mar 4, 2016 03:39 PM
