R50/53 Tire Pressure Question
Old Feb 4, 2016 | 10:15 AM
Drumsound's Avatar
Drumsound
So, My '06 MCS has the little sticker on the driver's door that says 35 PSI, but the sidewall of the Yokohama tires says max 51 PSI. That's quite a difference and I'm not sure what pressure at which I should be keeping the tires.
They aren't run flats, and I have the 17" rims.
Old Feb 4, 2016 | 10:25 AM
IQRaceworks's Avatar
IQRaceworks
You're best bet is to go with what the sticker on the door says. Those tires can go on all kinds of different cars.....the max printed on them is just that...it's the MAX, not what you "should" run.
I run 35psi in my tires...no issues at all. I've gone up to 38psi, and down to 32psi.....and settled for right at 35psi on all 4.
Old Feb 4, 2016 | 10:33 AM
Drumsound's Avatar
Drumsound
Thanks, Ian. I know someone here would know the drill.
Old Feb 4, 2016 | 10:50 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
For me. Consider it pure guesswork. The mfg of the car specs the air pressure with OEM tires, but not all tires are created the same so I can't see it follows to the next tire. The concerned drivers use a professional pyrometer, which is beyond my level.
Old Feb 4, 2016 | 10:59 AM
sevin's Avatar
sevin
You should never fill the tires with the max pressure listed on the sidewall. Always fill them to the pressures listed on the tire information label in the door jamb. You can overfill a few psi during the colder months to account for deflation caused by the lower temperatures.
Old Feb 4, 2016 | 11:53 AM
nkfry's Avatar
nkfry
Tire pressure is all subjective.
The runflats are so stiff that you could realistically run about 20 PSI and be fine, but conventional tires will vary. Not to mention it depends on what you're doing, you will want to run a different pressure for daily driving and fine tune pressures for a track day.
36 is perfect for these cars, as you have a perfect foot print and ride quality.
But don't run 51 PSI, it makes for an uncomfortable ride. That just denotes how much the tire is rated for, always start at what the door sticker says, but again subjective depending on what you're doing.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 4, 2016 | 11:56 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yep, stick with the door jam sticker as mentioned above. That's always your safest bet to stick with. Overfilling will cause abnormal tire wear causing you the need to get new tires sooner rather than later. Can't tell you how many times I saw this when working at the dealer.
888.280.7799 | 6am - 5pm PST
Old Feb 4, 2016 | 11:57 AM
Drumsound's Avatar
Drumsound
Thanks, everyone!
pokeyjoe
Sep 9, 2018 04:47 AM
otto_my_way
22
Jun 9, 2016 09:53 PM
Quijote
May 31, 2016 04:42 AM
R56YouSankMyBattleship
Feb 9, 2016 02:57 PM
MOMINIDC
Feb 4, 2016 04:01 PM
