R50/53 R53 threeway connector missing a hose.
Old Aug 3, 2015 | 05:46 AM
jcwswede's Avatar
jcwswede
Hi
I really cant figure out what hose is missing here?
1 goes to the airfilterbox
1 goes to the bypassvalve (hope Im right?)
But what about the third connection here? Got input that It might be a cable that goes from the manifold intake. But cant find were.
Any help is appreciated. I have been googling so much now that I cant come up with more ideeas to search for.
I have a idle stall problem wich occurs everytime and not from time to time
Old Aug 3, 2015 | 07:16 AM
batrugger's Avatar
batrugger
Do you have an automatic? That doesn't sound right at all. These might help you:
http://www.realoem.com/bmw/enUS/show...diagId=13_0977
4 connects to the brass nipple on the bypass valve and 6 connects to the bottom of 4
http://www.realoem.com/bmw/enUS/show...diagId=13_0978
13 connects to the bottom of the fuel pressure regulator and the intake manifold. If you have a boost gauge it will be spliced into this line too
http://www.realoem.com/bmw/enUS/show...diagId=11_3788
1 goes from the brake booster to the intake tube and if you have an automatic there is a line that branches off and connects to the intake tube. There is also a hose that connects to the valve cover on the drivers side and connects to the intake tube.
Old Aug 3, 2015 | 12:56 PM
Looks like a JCW Factory intake hose vacuum line.
Just posted up here:
https://www.northamericanmotoring.co...ease-help.html
Old Aug 4, 2015 | 10:52 AM
jcwswede's Avatar
jcwswede
Big thanks to booth of you. I will try to locate the third hose tonight although Im not really sure where it can be. Been looking everywhere
Old Aug 4, 2015 | 11:08 AM
You are welcome , the install PDF has a picture on the #3 install Page. You are overseas ?
Old Aug 5, 2015 | 12:42 AM
jcwswede's Avatar
jcwswede
Esctuning, I found the third hose! Thank you!
Still got big problems with the idle though, posted some new information in the other thread.
https://www.northamericanmotoring.com...ease-help.html
Would be very thankful If you would read the update.
yes Im overseas, Im from Sweden
Old Aug 5, 2015 | 06:52 AM
You are welcome. I would inspect all the vacuum lines for leaks, sounds like MAP and vacuum problem.
iggi
18
Feb 9, 2026 01:00 AM
KrisMiss
Jan 3, 2016 02:02 PM
timwhayden
Aug 24, 2015 08:42 PM
Super Coop
Aug 17, 2015 05:09 PM
minipopkart
Aug 13, 2015 05:22 AM
