R50/53 Camshaft Position Sensor??
Old Aug 3, 2015 | 08:52 AM
pocketmaster's Avatar
pocketmaster
My sons 05 MCS w/115k miles....throwing a p0340 code Bank "A". Is there more than one Camshaft Position Sensor on these?? I am only seeing the one on the passenger side directly behind the motor mount ....if thats what I'm looking at. Are these prone for failure with this many miles ?? Im assuming this is whats causing the struggle with starting.
Old Aug 3, 2015 | 09:31 AM
batrugger's Avatar
batrugger
Yes there is only one sensor here:
http://www.realoem.com/bmw/enUS/show...diagId=11_3086
and a thread with the same issue:
https://www.northamericanmotoring.co...on-sensor.html
Old Aug 3, 2015 | 09:43 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Here is some good info about the code as well. Part here if needed.
888.280.7799 | 6am - 5pm PST
Old Aug 3, 2015 | 09:52 AM
pocketmaster
How much voltage should be going to the sensor?? Just checking the circuit till the new sensor comes in
Old Aug 3, 2015 | 11:44 AM
batrugger's Avatar
batrugger
7ma to 14ma with a hall effect pattern
Old Aug 3, 2015 | 12:18 PM
Check the wire going to it also and the plug to make sure the connection is good before you replace it. Comes with a little o ring also.
http://www.ecstuning.com/Search/SiteSearch/12141485845/
Old Aug 3, 2015 | 01:46 PM
pocketmaster
I assume you mean DC referring 5o the pattern
Old Aug 3, 2015 | 02:12 PM
batrugger's Avatar
batrugger
Yes and its a square wave, but AC or DC only matters when measuring volts not miliamps. You can test for DC volts. One wire is power 12v, one is ground, and the other will be the signal wire that you can test for volts or frequency while the engine is cranking.
Old Aug 4, 2015 | 11:45 AM
pocketmaster
After disconnecting the connector and testing the circuit (tested good) I reconnected it and it started great....I'm guessing it's needing replacing.
Old Aug 4, 2015 | 09:32 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If you need I have some used ones.
Old Aug 5, 2015 | 07:20 AM
pocketmaster
Thanks .....I ordered one a couple days ago.
UncDeo
Nov 4, 2019 04:08 AM
CRC
Dec 26, 2015 11:30 AM
eliseo1981
Sep 30, 2015 01:53 PM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
renchjeep
Sep 6, 2015 01:54 PM
