R50/53 Tackling a p2096
Old Jul 23, 2015 | 05:41 AM
Saltysalt's Avatar
Saltysalt
Tackling a p2096
Hey fellas, I have my stupid p2096 on. I was wondering if anyone knew of any areas to also check.
I replaced the mid pipe gasket and the manifold gasket recently.
the manifold gasket was replaced with an aftermarket header. mid pipe gasket was replaced two weeks ago.
my next step is to check my 02 sensors and see if they are dirty and seated right.
but my car ran without this code with the header for a month, until minis on top when it got cool at night. figured that's when the mid pipe gasket gave up, and I was right. replaced the mid pipe gasket and the code disappeared for 30 min, until I went into auto zone to get oil for my motorcycle, then it popped up again
Old Jul 23, 2015 | 09:39 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Check out this thread on NAM. Post #4, provides links to 2 other threads with some good info. Maybe check them out and see if they help at all.
888.280.7799 | 6am - 5pm PST
Old Jul 23, 2015 | 10:19 AM
Saltysalt's Avatar
Saltysalt
that is interesting, granted im not getting worse gas mileage, and it doesn't seem like im getting bad performance.
but it says the flash works on 03-04, I have an 05
Old Jul 23, 2015 | 10:38 AM
PelicanParts.com
Vendor
Look at post #5 here. He has an '05 as well. Continue reading after that post. Post #32 here has some good info as well. There's a lot of information in that thread that may be helpful or may be irrelevant in your case, but at least it can give you some ideas.
Old Jul 23, 2015 | 10:59 AM
Da_Ghost's Avatar
Da_Ghost
Mine was affecting performance, I couldn't even move the car a couple feet since it was running really badly. In my case, it was a cracked intercooler boot, air was getting in and messing the a/f ratio, making it run lean as hell. It's most likely not your issue tho, looks more like an exhaust leak or something tricking the sensor into thinking the car is running lean.
Old Jul 23, 2015 | 11:09 AM
Saltysalt's Avatar
Saltysalt
im thinking it has to be something stupid, I had this same issue when I installed a cat back, I pulled the rear sensor and sprayed it with carb clean, haven't had the issue, but that was bank 2 sensor lean, not bank 1.
I wonder if I could do that to the top one, granted that's a bit tougher to get too.
elverado
Jan 18, 2022 02:51 AM
JLSM511
Feb 25, 2016 01:02 PM
ShadyCoop
Aug 24, 2015 06:05 AM
minipopkart
Aug 13, 2015 05:22 AM
Lt. Dan
Aug 10, 2015 08:23 AM
