R50/53 R50 Boot & Bonnet MINI Emblems
You can get them at all major mini retailers. Out motoring, ecs tuning, mini mania, your local dealer. I ordered mine from rmeuropean while ordering other various parts as they have free shipping on orders of $70 or more. My goal is to totally restore my r53 and get another 10 years out of it.
Whenever I see a MINI with the insert missing on the badge(s), I have to wonder what else is being neglected on the car. When I bought my car it was missing the black portion of badge. I've since caught up with the maintenance that was not done and yes, I have a new bonnet badge. Makes the front look new again. Took about 20 minutes to replace using a hair drier and dental floss. A little Goo-Gone to clean up the residue and the rest is icing on the cake. I still look at it almost every time I get in the car.
We keep them in stock as we see them missing all the time. Most the time it's car washes that wash them away. http://www.waymotorworks.com/oem-mini-wings-badge.html
We have them here and some tricks :
Setting the car in the sun or heat helps pull the old one off and +1 on the dental floss trick , working for the sides first seem to help.
Removing of the foam residue the some WD40 or any other substance of similar removal chemical will work, prep the surface clean helps adhere the new one, remove all the grease.
Line it up with the pins and make sure its aligned properly straight.
Just make sure you get the correct emblem for the front. Peal and stick application.
Gen 1 R53 & R52 MINI Cooper S "Hood" Emblem is smaller Part number 51140660106
http://www.ecstuning.com/Search/SiteSearch/51140660106/ES78841/
Gen 1 R50 & R52 MINI Cooper "base" or Justa (no hood scoop ) "Hood" Emblem is bigger.
Part number 51147026184
http://www.ecstuning.com/Search/SiteSearch/51147026184/ES79249/
Also the Gen 1 R50 R52 R53 MINI Cooper & Cooper S share the same "trunk" emblem.
http://www.ecstuning.com/Search/SiteSearch/51147026186/
mrjolliff
Oct 9, 2015 05:55 AM
bctf1
Aug 6, 2015 12:55 PM
