R50/53 Upcoming Oil Change
Old Jul 3, 2015 | 06:54 AM
JaysinStrife's Avatar
JaysinStrife
Upcoming Oil Change
I the inevitable is coming and I'm normally not someone that sticks with conventuals oil. So Id like to hear what you guys are running.
Sticking with Castrol, using Royal Purple, Redline, or even Amsoil? Feedback is appreciated guys!
Old Jul 3, 2015 | 09:27 AM
gpwpat's Avatar
gpwpat
Mobil 1 full synthetic. I change it every 10k miles or so. Pretty much twice a year. After 13 years and 233k miles I'm still running strong. Really strong. I have been using the same oil in this car since new. Best price is at Wal-Mart $25 for a 5 quart bottle.
Old Jul 3, 2015 | 10:25 AM
Capt_bj's Avatar
Capt_bj
read the owner's manual
MINI calls for full synthetic ... as long as you stick with a good full s' and the proper weight range you'll be fine.
Some folks have big brand loyalty. Some insist on only oil they get from the dealer. In the early days the aftermarket filters often had problems so folks recommend OE filters even today (I have not seen this problem in at least 5 years, myself)
I too buy MOBIL ONE in the 5 quart jug from Wally World and never had a problem ... I do changes for other folks and use whatever they bring .... I've used "MINI" and Castor the most with no problems seen there either.
IF this is your first time doing a change on a GEN1 I recommend you do some searching here for the DIY and other hints. There are a couple of GOTCHA's to be aware of including
1. The OE drain plug has a tendency to get stuck due to a poor design using a built on plastic seal. The OE plug is SUPPOSED to be used ONCE but seldom is replaced.
2. The recommended metric socket size is metric and WRONG. If the bung sticks AND you use the recommended metric socket, the chances of stripping the head increase. Try a 1/2 inch .... it fits better.
3. STRONGLY recommend you replace the bung with a FUMOTO valve and never worry about this in the future . . .
4. The filter can can be a bit*h to get back on .... try some practice runs without a filter in the can.
5. The filter holder can be a bit*h to get off ..... there isn't a lot of clearance for the BIG socket and the wrench ....
if you can't find the DIY, pm me with an e-mail address and I'll send as a PDF
Old Jul 3, 2015 | 10:58 AM
rckrzy1's Avatar
rckrzy1
ok here is from my documented experience with actual lab results. I tested 2 cars albeit none were MINI's, one a trans am 5.7L far from stock and a 5.3L chevy PU . Both ran mobil 1 after break in. I saw a white paper and heard rumors mobil 1 changed formulas aka went cheap and I decided to switch oils to Q full synth , wear in BOTH vehicles dropped enough that it was tangible, to see if it was a fluke put mobil 1 back in cars and damn if the wear did not increase back to were it was.
So I am not ever using mobil 1 again except maybe my lawn mower.
Since you don't have a turbo you don't need to worry as much but it is a highly stressed engine so I would use full synthetic , if your going 8K between changes as I do you want a LONG LIFE oil.
I have been using MINI oil because my cars are under warranty and they can't ever blame me on that for any issues and my dealership does changes for $69.95 so I let them do it and there fore is documented as well.
There is a castrol edge EUROPEAN FORMULA long life 0-40W at walmart that I would use if you want to save money, like $27 for 5 qts, and it's BMW long life full synthetic rated oil.
Amsoil is great oil, they pretty much invented the stuff but it's pricey, that is what I use in my English (triumph) street triple R motorcycle, very high perf 3 cylinder that turns 14K rpm, never had any wear issues with that.
Old Jul 3, 2015 | 11:45 AM
ZippyNH's Avatar
ZippyNH
Your MINI REQUIRES syenthic oil...
Out if WARRENTY, so use what you want...
Mobil1 euro 0w-40 is good stuff, and meets the original factory requirements...
It is very different stuff from the regular mobil1 which is technically now a highly upgraded conventional oil...like most oils, called a group 4...
I have also used various castrol syenthic oil...
All were fine, cheap at Wally world, at about $20-25 for 5 liters, after bring on sale, often with a rebate...
Read oil change threads...
Get a OEM/Mann/ mahle filter...oil the gasket, and have fun!!
Yes..oil changes on a MINI are different...
Mini says 15,000 miles with an "approved" oil...
I usually went 7500 or 6 months...
Old Jul 3, 2015 | 02:17 PM
Capt_bj's Avatar
Capt_bj
for your consideration
Old Jul 4, 2015 | 07:59 AM
JaysinStrife
Thanks for all the info guys!
Bj could you, or someone, link me to the Fumoto valve you referenced? I understand I shouldn't re-use the stock plug.
Also, I run Royal Purple in my modded XB, and in cars before that. I just wanted to make sure the RP for the Mini will be good.
Old Jul 4, 2015 | 10:47 AM
MiniMello's Avatar
MiniMello
mobile 1 0W40 here since I got it never an issue at all maybe a 1/4 of a quart is lost between changes, 16 mm on the drain plug on mine not 1/2 inch tho. Order your filter online or the local places will charge over 25$ for ones in stock I have seen it several times where I am.
Old Jul 4, 2015 | 12:16 PM
RogueMini's Avatar
RogueMini
+1 on the fumoto valve. Makes an oil change quick and easy. I think bmw recommends changing the plug each oil change anyway, even though most people dont, you will strip the hex off and have to replace it evantually.
Get some inexpensive ramps from harbor freight, or somethin (a must when working on a MINI).
- pull the car up on the ramps
- put a drain pan under the car and open the fumoto valve
- loosen the oil filter cap enough to break the seal, but dont remove it
- go have beer/watch the last qtr of the game (this gives the filter time to drain)
- replace oil filter with new MANN and reinstall oil filter cap
- close the fumoto and put in new syn oil
- motor
Old Jul 4, 2015 | 01:04 PM
rckrzy1's Avatar
rckrzy1
Well Mobil 1 pulled a change a while back , fool me once...... s not going back to them.
15K ? My wife's 2012 says 16K , that is just ludicrous. No oil last that long that I ever tested, at 8k blackstone labs says it's about out of it's additives. And even then the amout of contaminants is high, unless we had some super efficient particulate filters like diesels I would not try more than 8K , especially with the tiny oil filter MINI has. Whomever said 16K was ok should be tarred and feathered.
Old Jul 4, 2015 | 01:15 PM
MINI_42's Avatar
MINI_42
My stealer charges $69.95 for an MCS oil change, but for my R56 JCW they want $139!
Thanks Mini of the Woodlands, I'll do it myself every 3 - 5,000 miles.
Old Jul 4, 2015 | 04:08 PM
Drivehard's Avatar
Drivehard
Originally Posted by MINI_42
My stealer charges $69.95 for an MCS oil change, but for my R56 JCW they want $139! Thanks Mini of the Woodlands, I'll do it myself every 3 - 5,000 miles.
That's odd. What's the difference between the 2?
Oh. And to the OP. MOBILE1 euro 0w-40 here and OEM oil filter. Oil from Walmart as stated earlier. Look for rebate coupon.
on the new cars the interval is no longer 15k it's 10, actually mine read 9k after only 100 miles since new. So I'll be doing the every 4500 ish interval in between the maint warranty changes.
Sent from my iPad using NAMotoring
Old Jul 4, 2015 | 04:19 PM
MINI_42's Avatar
MINI_42
I guess the difference is the letters 'JCW'. I suppose that means 'Just Cash Wasting'.
Old Jul 4, 2015 | 04:24 PM
Capt_bj's Avatar
Capt_bj
http://www.qwikvalve.com/search.php?mode=search&page=1
Old Jul 4, 2015 | 05:23 PM
RogueMini's Avatar
RogueMini
Outmotoring sells them too, convenient if you are already ordering other mini goodies (like a 6-pack of oil filters).
Old Jul 5, 2015 | 03:00 PM
jc8825's Avatar
jc8825
I use Valvoline SynPower 5W30 in the 06 and will in the 05. Great stuff and engine always verified with oil analysis.
Also oil doesn't go bad on time alone. There are other factors, but I had the oil analyzed in the 06 after 2.5 years and 2600 miles and it was still in good enough condition to run another 10K.
Old Jul 7, 2015 | 10:51 PM
IslandJCW's Avatar
IslandJCW
05 JCW...I use Mobil One 0w40 European Formula
Old Jul 8, 2015 | 04:47 AM
Piano Man's Avatar
Piano Man
I used to use Mobile, but now use Amsoil 5-30 in my '05 MCS. My son and I do it ourselves.
Old Jul 8, 2015 | 05:01 AM
JABowders's Avatar
JABowders
Veteran: Army
Oil Drain Plug should be a 13mm (1/2 works but not really correct as it measures 12.7mm)
Also go ahead a get a spare plug they are cheaper than you think... lowest price is about $2.50. No need to have one that is all buggered up.
Motor on!
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
patpatpat
Aug 27, 2015 07:51 AM
HaveATank
Aug 24, 2015 10:26 AM
