R50/53 Planning a bunch of repairs at once - What else?
Old Jun 17, 2015 | 09:06 AM
dcantwell's Avatar
dcantwell
2003 R53 with 170K Miles.
Since it sucks to put the car in front end service mode, I'm trying to bang a bunch of stuff out at once. I've been searching the forums for a few days to figure out important items to address.
Here's what I've thought of:
- Change Supercharger oil, all related gaskets. (See link below)
- Replace Serpentine Belt
- Replace Belt Tensioner
- Replace Crank Position Sensor O-Ring
- Replace Valve Cover Gasket
- Replace Spark Plugs
- Replace water hoses???? (Not sure what or how many)
I want to try and do this all in a weekend. So getting all the parts in advance is ideal. if you have a link to the items, please share. I've found various links all over the place.
Here's a parts list so far:
- Supercharger oil: http://amzn.to/1GfpGuh
- Supercharger Input Gasket: http://amzn.to/1QEc5ri
- Throttle Body O-Ring: http://amzn.to/1Gt5vMy
- Water Pump O-ring: http://amzn.to/1N2K2wc
- Serpentine Belt: http://amzn.to/1Tukexv
- Serpentine Belt Tensioner: http://bit.ly/1BnpddA
- Crank Position Sensor O-Ring: http://bit.ly/1FmCVIH
- Valve Cover Gasket: http://amzn.to/1Soiswm
- Spark Plugs: Suggestions???
- Hoses???
- Coolant
I'm leaking oil pretty bad and I've been told it's my valve cover gasket and the CPS o-Ring. Any other places?
Any other items to address? Trying to be pro-active.
Thanks for your help!
Dave
VENDORS: If you can beat prices on parts, maybe I'll buy from you
Changing SC Oil:
https://www.northamericanmotoring.co...ge-how-to.html
Old Jun 17, 2015 | 09:35 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
The list is looking good! If you need any help while digging into your MINI you can use our tech articles here. Can look under engine to see other viable fixing options to do while you're in there. Maybe change out your ignition coils while you're doing all of this if you haven't already. Genuine spark plugs are probably your best bet, otherwise Bosch is a good product as well. This thread here is a good read about common oil leaks with the R53. Water hose options here. Good luck! Looks like a fun weekend you've got planned.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 18, 2015 | 01:35 AM
silence2-38554's Avatar
silence2-38554
Change your oil dipstick tube o-ring while you're in there! When I was doing my supercharger oil, I pulled everything apart only to find that it was leaking worse than my CPS o-ring. Also, have some fresh new vacuum hose on hand & replace the short bit of line that goes to the bypass valve. It tends to get rock hard & is not accessible at all unless in front end service mode.
Old Jun 18, 2015 | 04:01 AM
Stinch's Avatar
Stinch
Even though it was working fine, I replaced my water pump after the s/c oil was changed.
Old Jun 18, 2015 | 04:34 AM
dcantwell's Avatar
dcantwell
They seem like great ideas. Do you have an image or link to the hose?
Thanks a bunch!
Old Jun 18, 2015 | 04:49 AM
dcantwell's Avatar
dcantwell
Makes sense. It's not an expensive part and the S/C will be off.
Did you replace the flange? What gaskets?
Old Jun 18, 2015 | 04:57 AM
Nicefeet's Avatar
Nicefeet
Don't forget to change the block outlet o-ring for the water pump. There's a flange that bolts to the block that has an o-ring.
There's also a block off plate behind the supercharger that has an o-ring.
Old Jun 18, 2015 | 05:36 AM
JABowders's Avatar
JABowders
Veteran: Army
With the age of the car, I would really inspect all the rubber... intake hoses, vacuum lines, connectors, coolant and heater lines, power steering hoses, bushing, bearings, mounts... and ALL the sensor O-rings...
History shows us it the $0.50 part that causes the $500.00 part to fail...
And to quote Chief Mechanic Obvious, plan out your work, no sense getting elbow deep in a repair to realize you will have to do it all over again because of an auxiliary part you don't have on hand.
Best of luck with what you do ... and ...
Motor on!
BushOner
Mar 12, 2022 08:51 PM
donniedarko
Oct 21, 2015 01:15 PM
Panik
Sep 9, 2015 08:36 AM
Sep 4, 2015 03:56 PM
Sep 4, 2015 09:10 AM
