R50/53 R53 ac not blowing cold but full.
Old Jun 2, 2014 | 06:34 PM
Jones424's Avatar
Jones424
We'll well.
I've now had the car almost 3 months and yet another issue.
Back story got the car ac was not working check the system and it was empty found a line was bad replaced it and filled the system and all worked flawless.
Now it stopped blowing cold so instantly checked for freon and all is full. Even pulled all freon out and checked for leaked by pulling a vacuum and refilled the system still nothing.
Fan is kicking on.
Compressor is kicking on.
Blower motor is working.
What am I missing?
Using a snap on ac machine not just hand gauges.
Old Jun 2, 2014 | 07:34 PM
JAB 67's Avatar
JAB 67
Have you checked your cabin air filter?
Old Jun 2, 2014 | 07:38 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by Jones424
...What am I missing?
When was the last time you changed the cabin air filter? Even a partially clogged one will cut the AC efficiency a bunch.
I was thinking of posting a “Don’t complain about AC problems unless you first change the cabin air filter” thread.
I have seen a lot of damage caused by people doing all sorts of things with part store charge kits when the only thing that was wrong was this CAF being dirty. It needs to be changed every year. More often if you smoke or are in dusty climates.
///Rich
Old Jun 2, 2014 | 07:50 PM
Jones424's Avatar
Jones424
Changed it with a new one from napa a month or so ago
Old Jun 2, 2014 | 07:58 PM
ZippyNH's Avatar
ZippyNH
Change the dryer?
If the PSI was zero...bet there was moisture....also refill the oil right?
If all those are done...Expansion valve/Orifice...
Then again..you have the fancy machine!! LOL
If you are sure it is working....have you checked that the blend door is closed...the heater core is always hot...
Old Jun 3, 2014 | 06:05 AM
Jones424's Avatar
Jones424
Originally Posted by ZippyNH
Change the dryer?
haha wouldn't say fancy but a nice digital machine that tells me whats going on then me having to read and try to figure out gauges.
all the controls work as the should on the dash ill have to tare into it to check the actual movement of the unit.
does anyone have picture or a place of a break down so I can see what im getting into.
expansion valve how will that affect anything? or should i ask what does the expansion valve do?
Old Jun 3, 2014 | 09:19 AM
Jones424's Avatar
Jones424
I do not have Auto Climate Control.
the compressor is kicking on and fans seems to be working fine.
I been looking into this and seems like i could be having an issue with two expansion valve or dryer being clogged?
Im at a loss honestly. my other issue is the line to the evaporator isn't even cold.
but the machine is telling me the pressure on the lines are good.
Old Jun 3, 2014 | 10:15 AM
JAB 67's Avatar
JAB 67
Please keep us informed as to your progress and end-result, as I am in the same situation as you.
Old Jun 3, 2014 | 10:35 AM
Jones424's Avatar
Jones424
I will do for sure. Im just at a complete loss right now.
Im going to dig into the dash and see if the blend door is still functioning and sealing perfectly.
still doesn't answer my evap line not being cold.
Old Jun 3, 2014 | 11:58 AM
JAB 67's Avatar
JAB 67
The possibility for which you need to prepare yourself is the conclusion that the compressor has self-destructed. There is still sufficient refrigerant in the lines to satisfy the pressure switch, and the compressor clutch still works so the compressor engages, but although the compressor spins it does not "compress." Dealer quoted me $1,500 to repair, and that did not appear to include receiver/dryer or expansion valve.
Old Jun 3, 2014 | 12:02 PM
Jones424's Avatar
Jones424
so your saying that the compressor can kick on (engage the clutch) yet still not be working properly?
But then why would this still give me decent pressure in the lines?
Old Jun 3, 2014 | 12:25 PM
Jones424's Avatar
Jones424
try this again see if i get the same results
Old Jun 3, 2014 | 05:29 PM
ZippyNH's Avatar
ZippyNH
My thoughts....
Moisture can destroy a pump....and you had zero psi...fixed a line...and did not change the dryer...kudous to you for getting a full vacume on the system...the dryer acts as a filter and as ac moisture remover....it is considered good practice to replace it anytime the system is opened...
Bet the oil if you opened it up looks like graphite sludge from the compressor self destructing.... Just a guess... Shame sounds like you did most stuff better than most...check around...there are various places selling compressors and kits with dryers and valves.... Just be sure to flush the system clean if the oil is contaminated...or the new pump will fail too.
One thought....I don't think any of us responding is a pro ..might be with an hour in a shop to be sure....
Old Jun 4, 2014 | 10:06 AM
Jones424's Avatar
Jones424
ok new findings.
HIGH PRESSURE lower condensor line that runs to the expansion valve had a small hole rubbed in it next to the strut tower on the drivers side.
problem is the thing showed full and pressure was holding but it was so small the pressure did show but wasn't making it to the evap.
new hose on order.
Ill be sure to check the system and oil prior.
Old Jun 10, 2014 | 08:34 AM
Jones424's Avatar
Jones424
alright guys my issue is finally fixed.
My issue was the line I installed last time was slightly bent when installed and after driving for the last month it rubbed against the motor mount and rubbed a hole in it.
still doesn't answer any of my answers or my issues above guess the leak we so small at first didn't detect at first but still affecting cooling?
Attached Thumbnails R53 ac not blowing cold but full.-photo-1-1-.jpg   R53 ac not blowing cold but full.-photo-2-1-.jpg   R53 ac not blowing cold but full.-photo-4.jpg
Old Jun 10, 2014 | 08:35 AM
Jones424's Avatar
Jones424
and the line with the hole
Attached Thumbnails R53 ac not blowing cold but full.-photo-3-1-.jpg   R53 ac not blowing cold but full.-photo-5.jpg
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
W0TM8
Dec 19, 2019 07:50 AM
Fizzyx
Aug 14, 2015 08:24 PM
minipopkart
Aug 13, 2015 05:22 AM
