R50/53 Where can I get new dust seals for my rear calipers?
I'm putting new pads on, and while I was in the process of twisting the rear caliper piston to compress it.....the dust boot/seal turn. I've heard you can get new dust boots for the rear calipers, but I've been searching all over the net and I can't seem to find them.
Any help would be great!! I don't want to replace the whole caliper just because of a turn dust seal.
Thanks guys!!!
Thanks guys!!!
Here are the rear Dust boots, or dust caps:
http://www.ecstuning.com/Search/SiteSearch/34216757250/
Welcome. Good time to inspect other parts on the rear caliper also like the bushings
Guide Bushing Set - Priced Per Caliper
http://www.ecstuning.com/Search/SiteSearch/ES59450__ES1966737__ES2642869/
and to make sure you don't have a broken rear spring clip.
http://www.ecstuning.com/Search/SiteSearch/34216762749/
Clean the guide bolts off and if there damaged or etched really bad you can replace them. Otherwise some Emory paper or a very fine grade sandpaper. Two per rear caliper.
http://www.ecstuning.com/Search/SiteSearch/ES59451__ES2628388__ES2574677/
Jason
Is there any real difference in the $3 rockauto seals and the $20+ seals from ECS or WMW?
I don't know if there is a difference or not. The $3 ones have been working well on my car for a few years (daily driver in snow and salt/autox/ occasional track duty). I'm sure the OEM MINI parts are top quality too.
squawSkiBum
Oct 2, 2015 09:21 AM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
