R50/53 Will non-mini OBDII scanners work on a mini?
Old Feb 8, 2014 | 05:47 PM
IQRaceworks's Avatar
IQRaceworks
Maybe this is a stupid question....but I have an OBD2 code scanner for a Dodge Truck....and I was thinking about plugging it into the OBD2 port on my R53 to see if it would work. It will also read sensors, intake temps, speed, rpm, stuff like that.
I didn't know if it would work since they are both OBD2 systems....or is the MINI OBD2 port set up differently than other vehicles?
I thought I would ask before I plugged it into my MINI and screwed something up.
Old Feb 8, 2014 | 06:19 PM
zrickety's Avatar
zrickety
I have a 'universal' obd2 scanner, but it doesn't work with our Mini. I think it really depends on the model, you should just plug it in and see. You can't hurt anything trying to read a code.
Old Feb 8, 2014 | 06:24 PM
05r50's Avatar
05r50
A quality scanner can read codes. But MINI does have some codes that only their tool seems to read.
Old Feb 8, 2014 | 06:52 PM
Locust's Avatar
Locust
I use a Kiwi PLX that interfaces the OBD port to WiFi to my iPod or iPad. Works great and allows me to add just about any gauge I want, including engine temperature. Allows me to clear the code as well
Old Feb 8, 2014 | 11:17 PM
Javskies's Avatar
Javskies
i got this one and works perfect with my android using the toque app. just like locust said i get pretty much any gauge i wont on my phone, like a boost gauge that records peak boost so i dont have to constantly look at it!
its the obd2-a
http://www.ebay.com/itm/Mini-ELM327-Interface-Bluetooth-OBD2-Auto-Car-Diagnostic-Scan-Tool-/190939548040?pt=LH_DefaultDomain_0&var=&hash=item2c74e24988
Old Feb 9, 2014 | 06:01 AM
Da_Ghost's Avatar
Da_Ghost
A generic OBDII reader will work for check engine light, some codes will lead you nowhere tho (Mini related codes that you'll have look up). For anything else, you need either a software with a laptop or a scanner.
Old Feb 9, 2014 | 06:33 AM
IQRaceworks
Will any of those Bluetooth iPhone apps also do data logging ?
That ELM327 Bluetooth deal off of ebay looks great, but I have an iphone. Are there any Bluetooth OBD connectors for MINI's that work with iphones?
Thanks for all the info guys!
Old Feb 9, 2014 | 10:13 AM
Stoker's Avatar
Stoker
Dash command uses a wi-fi setup.. That's what i Have. It works well enough..
Downside with the iPhone, The phone looks for data via the wi-fi network first..
slows it down. Go look on the apple website, they have a Pretty neat set up.
Old Feb 9, 2014 | 11:02 AM
bratling's Avatar
bratling
Super Moderator
Originally Posted by IQRaceworks
Will any of those Bluetooth iPhone apps also do data logging ? That ELM327 Bluetooth deal off of ebay looks great, but I have an iphone. Are there any Bluetooth OBD connectors for MINI's that work with iphones? Thanks for all the info guys!
This:
http://m.gopointtech.com/?dm_redirected=true#2858
I use an eBay cheapie and jailbroke my phone to use RoqyOBD.
Dec 23, 2015 10:36 AM
Lt. Dan
Aug 10, 2015 08:23 AM
joelcseymour
Aug 7, 2015 12:43 PM
nismo4life
Aug 5, 2015 08:31 AM
