R50/53 Lowering springs . Questions
Old Feb 1, 2014 | 08:13 AM
P4pumpman's Avatar
P4pumpman
I'm going to be putting on a set of 17 inch wheels with the normal 42 offset . I'd like my car to set a lil lower to eliminate some wheel/ fender gap . If I go with lowering springs , is there any thing else I need to lower it properly . Will it effect my alignment or keep me from getting a proper alignment ?
My car is a 05 r50
Old Feb 1, 2014 | 08:39 AM
ZippyNH's Avatar
ZippyNH
How wide is the new rims/tires? Rims are sold in multiple widths...just like tires...
At wider widths, some folks can have rubbing issues
Old Feb 1, 2014 | 09:53 AM
IQRaceworks's Avatar
IQRaceworks
I looked into doing the lowering springs on my JCW a year or so ago, and I decided against it. One thing that you are going to also need is a set of adjustable camber links for the rear to be able to get the correct camber after you lower it. Make sure you get the car aligned after you lower it. Also, what shocks are you running? I've heard that if you don't have a good set of shocks on your car, you car run into issue of bottom the suspension out all the time.
Old Feb 1, 2014 | 10:35 AM
P4pumpman's Avatar
P4pumpman
The rims are 7.5 wide and I'll be running a 205/45/17 tire .
What all should I expect?
Old Feb 1, 2014 | 10:54 AM
GreekDrifter91's Avatar
GreekDrifter91
unless you are going to seriosly drop it, dont do it with springs. even with a 1.5" drop i doubt your alignment is going to change much.
i am running 17x7.5 with 215/45/17 tire. my tires rub a bit but nothing crazy only when the shock bottoms out. i am also running koni yellows with swift springs. now they dont drop much 3/4'' in front and 1/2'' in the rear. but i bought them for other reasons. not to get lowered thats just a little cherry on the cake.
Old Feb 1, 2014 | 11:06 AM
P4pumpman's Avatar
P4pumpman
I'm not looking to have my tires up inside the wheel well . I just want to have a lil less wheels gap. I'm not looking to slam my car . I'm running a 16 wheel now and I'm hoping the 17s will fill in the wheel well better then I'll see about the springs .
Old Feb 1, 2014 | 11:22 AM
P4pumpman's Avatar
P4pumpman
I just installed a new set of Monroe shocks all around .
What would be the best way to lower it just a half inch or so?
Old Feb 1, 2014 | 12:04 PM
GreekDrifter91
swift springs i think they might be the smallest drop out of all the springs. and they give the car a nice ride and support through the corners. the higher rear spring rate also helps the car rotate a bit more but not much
their specs....
Also this thread may help your selection process
https://www.northamericanmotoring.co...ring-info.html
Old Feb 1, 2014 | 12:40 PM
P4pumpman's Avatar
P4pumpman
That's about as low as I'd like to go . So if I only drop it a half inch ,will it greatly affect my camber?
Old Feb 1, 2014 | 12:44 PM
GreekDrifter91
nope, it takes quit a bit of lowering to affect camber and other aspects of your tires orientation. probably 1.5 to 2.5 is where you see big camber changes. and you need adjustable control arms and camber plates
Edit: also you need to take in account the angle or the control arms as well when you lower a car to much(im talking like 1.5-4 inches) the the control arms will point up and that ruins your suspension geometry big time and ruins how well a car handles
Old Feb 1, 2014 | 01:07 PM
P4pumpman's Avatar
P4pumpman
Thanks so much .
So I should be ok as long as I stay under a 1inch drop.
Thanks again
Old Feb 1, 2014 | 08:08 PM
GreekDrifter91
yea, 1 inch is good no real need to "fix" anything with that much. and should fill in the gap alright. like i said i run 215/45/17 and the 3/4 and 1/2 that the swifts gave me did a good job. it gave me just the right amount that i like.
jeremy_reyes94
Sep 6, 2019 07:53 AM
melscoop
Mar 30, 2016 06:56 PM
G1HQ
Aug 28, 2015 01:41 PM
yukinoinu
15
Aug 24, 2015 09:20 AM
Emnotek
Aug 13, 2015 05:47 PM
