R50/53 Catch can filling up
Old Dec 17, 2013 | 04:28 AM
lathedog's Avatar
lathedog
I put an Alta catch can on my car last year. I have noticed that it fills with water fairly fast.I would say in a thousand miles it is full .I have drained it several times and am amazed at how much water it gets.Do others have have the same experience ?
Old Dec 17, 2013 | 05:39 AM
yetti96's Avatar
yetti96
In the winter it is filling with condensation.
Old Dec 17, 2013 | 05:43 AM
lathedog's Avatar
lathedog
It was filling in the summer.I don't drive it in the winter
Old Dec 17, 2013 | 07:32 AM
Ian Landesman's Avatar
Ian Landesman
I installed mine about a 1000 miles ago, and although there is condensation inside, when I open it to drain, there is not enough for anything to come out. Depending on your climate, I'd say it could be normal.
Old Dec 19, 2013 | 07:01 PM
astroBlackMetallic_Mini's Avatar
water? that doesnt sound right. i only get oily gassy stuff in mine...
Old Dec 20, 2013 | 04:29 AM
lathedog's Avatar
lathedog
That's all it is.makes me wonder if it's sucking water from an external location.
Old Dec 20, 2013 | 10:41 AM
RayH's Avatar
RayH
Water is a byproduct of combustion so if you've got leaky valve stem seals or piston rings you're going to end up up with more in your oil. Part of the function of the PCV is to vent off the water contained in steam to be burned rather than sludge up the engine. I wouldn't be to concerned unless you're burning a lot of oil. Just make sure you do not let the water freeze in the catchcan in such a way that it prevents it from venting.
Old Dec 20, 2013 | 10:50 AM
lathedog's Avatar
lathedog
Car only has 36000 miles and runs perfect.never had milky oil before I put this on a year ago. Still thinking it sucking rain water from somewhere
Old Dec 20, 2013 | 12:17 PM
ZippyNH's Avatar
ZippyNH
+1
Catch can is working...and is in a good location...a nice cool one...
Lots of short trips cause it to catch water....e-10 fuel even more.
Nothing is wrong. All is good. Just be sure to Empty it regularly. Failure to empty the water out can result in an engine failure....
scfiveo
Sep 27, 2019 02:27 PM
dinomaniac
Sep 18, 2018 04:19 AM
OutMotoring
Nov 16, 2015 07:04 AM
martinb
Oct 7, 2015 05:00 PM
aldito2
Sep 30, 2015 10:44 AM
