R50/53 HELP!! Check engine flashing, DSC light on, rough idle
Old Oct 22, 2013 | 04:21 AM
Mjimport's Avatar
Mjimport
So I made it all 20 miles to work and as I'm pulling in to my parking spot my mini starts to rough idle, the check engine is flashing and the DSC light comes on.
I don't see any fluids anywhere, is that a good sign?
Is there something I can check myself or do I need a shop to scan the code?
Old Oct 22, 2013 | 05:10 AM
Saltysalt's Avatar
Saltysalt
i would scan the code, you could have a misfire or vacume leak
Old Oct 22, 2013 | 06:48 AM
Mjimport's Avatar
Mjimport
Looks like I'll tow it to bmw, the mini dealer is 2 hours away :(
Mini told me only bmw or mini can read codes fully to pinpoint what is wrong, true?
Old Oct 22, 2013 | 07:00 AM
cerenkov's Avatar
cerenkov
Partly true. Some generic code readers will not fully read some MINI specific codes. They will only output a generic code. Any shop not just the dealer CAN (but might not) have the proper diagnostic reader.
Old Oct 22, 2013 | 07:16 AM
vietnameeh's Avatar
vietnameeh
your car went into limp mode... i would scan the codes... but you might be able to start it up again and see if it gets out of limp mode.. i would open the hood and check spark plug wire connections.. etc you might be getting a misfire code or something
Old Oct 22, 2013 | 07:27 AM
Mjimport's Avatar
Mjimport
I pulled the wires, nothing appears out of place. I changed plugs a year ago but coils are original I'm sure.
Called my local indi and he is confident they can pinpoint. My check engine light was flashing at first, now when I start the car again it comes on solid, then dsc light comes on.
He thinks it is likely spark related
Old Oct 22, 2013 | 08:23 AM
Mjimport's Avatar
Mjimport
Old Oct 22, 2013 | 11:23 AM
ZippyNH's Avatar
ZippyNH
IMO no need to tow the car 2 hours to a dealer....
A good independent shop can get 99% of the codes.... Mini/BMW background will help, but bet they can handle it.
Hope it us a bad coil....
And not a valve issue....both possible depending on miles, prior history, and type of fuel usually used...lower than spec fuel, aka below 90 octane, can result in burnt valves....
Old Oct 25, 2013 | 03:15 PM
Mjimport's Avatar
Mjimport
Turns out it was just a loose spark plug. I changed the plugs myself many months ago, bu didn't have a torque wrench, tried the rule of thumb method. I can't believe it took this long to get loose, probably due to the sudden drop in temps, it dropped 30 degrees over night.
Old Oct 25, 2013 | 04:09 PM
Saltysalt's Avatar
Saltysalt
im glad it something as easy as that!
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
