R50/53 Lugnut removal
Old May 15, 2004 | 09:26 AM
REHutch's Avatar
REHutch
When you get the tires changed or rotated, do you let them use an air tool to remove the lug nuts? I am concerned that the can/will either over tighten them, put them on so they are impossible to remove, mar the lug nuts, or strip it out.
I have had two of these problems with my other cars. Do you tell them to losen them by hand then use the air tool, put it on with the air tool and then do the final work with the air tool?
I know this may sound ****, but when you are out in BFE at 2 am and you have one lug that just turns and will not come off.....well it just sucks.
REHUTCH
Old May 15, 2004 | 09:36 AM
JustGo4It_'s Avatar
JustGo4It_
Impact is ok for removal. Tighten the wheels with a torque wrench. Spec is 90 ft/lbs.
Old May 15, 2004 | 09:59 AM
Nick_T.'s Avatar
Nick_T.
Whenever a shop remounts a wheel for me I always retorque it when I get home.
Old May 15, 2004 | 11:17 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Also if you change wheels you will have to reset the runflat tire sensor-read your manual.
And if you autocross or do track events check your lugnut tightness in between sessions.
Old May 15, 2004 | 11:47 AM
Yucca Patrol's Avatar
Yucca Patrol
I recently had brake service at a MINI dealership and was irritated that when I got home and changed my wheels, I found they had overtorqued the lugs with an impact wrench.
Factory trained mechanics who should KNOW factory torque specs should NOT cut corners like that.
Old May 15, 2004 | 12:24 PM
2minis's Avatar
2minis
You should also re-check them after 50-100 miles.
Old May 16, 2004 | 08:17 AM
Jimbo's Avatar
Jimbo
All you guys and gals realize that the MINI has (in true BMW style) lug bolts rather than lug nuts, not that it matters for torque specs, but some of you may be suprised the first time you go to change your tire !
Old May 16, 2004 | 09:23 AM
Nick_T.'s Avatar
Nick_T.
Since the MINI uses lug bolts instead of the more common studs and lug nuts it can be a little difficult to remount a wheel, especially in the dark and rain. Strong-Strut sells a set of two wheelpins for US$25 which makes wheel mounting much easier.
I bought a set a long time ago for my Z3. The MINI and the Z3 have many common BMW parts, and the wheel lug bolts fall into this group.
Wheelpins
Old May 16, 2004 | 11:08 AM
MGCMAN's Avatar
MGCMAN
Also if you change wheels, you may need to get longer or shorter lugs. I know my Kosei wheels use a lug some 3 or 4 mm shorter than stock. Always use a torque wrench when changing wheels.
Old May 16, 2004 | 12:15 PM
OctaneGuy's Avatar
OctaneGuy
Hey Nick,
thanks for that tip. I just checked out that site, and sent off an email about ordering a pair. It's $25 which includes S/H.
Old May 16, 2004 | 12:31 PM
Yucca Patrol
Those wheel pins look cool. I'd sure like to try them once and see if I think they are worth it in saved time/effort.
I always like it when someone comes up with a clever and simple solution to a problem. . .
CAll me cheap, but I'll probably take a lug bolt with me next time I need to go to an industrial fastener shop and buy a couple long bolts with the same threading and then saw off its head. I'd be surprised if two such bolts cost more than $5. . . .
In fact, I'm almost certain that these pins are simply a bolt with the head cut off, tip rounded, and a hole drilled into it. . . .
_________________
SE Regional, BAMA Club Moderator: PM me
Old May 16, 2004 | 01:00 PM
OctaneGuy's Avatar
OctaneGuy
Hey Yucca,
Yep, that thought crossed my mind as well, but as simple as it is, someone went through the effort of making them, and I'd like to support that idea. Now if they were $25 EACH, that'd be a different story.
Old May 16, 2004 | 01:58 PM
Nick_T.'s Avatar
Nick_T.
No need to use the screwdriver to mount the pins - finger tight is enough - but it's nice to have the hole in case they are hard to remove.
Old May 16, 2004 | 06:51 PM
Ryephile's Avatar
Ryephile
HA! Air'ing on bolts is how the MORONs at Motor City MINI broke a bolt off my intake manifold. They used a 400lb-ft air gun to tighten a 15lb-ft spec screw!
:evil: :evil: :evil: :evil: :evil: :evil:
I can't express enough how representative this example is of their incompetence!
Old May 18, 2004 | 05:15 PM
pocketrocketowner's Avatar
pocketrocketowner
As long as you are gonna buy something, how about a set of wheel studs and nuts insted. About an hours's worth of toil and sweat. I thin $60.00 and you have studs, forever.......I hate lug bolts!
Old May 18, 2004 | 05:26 PM
early_apex
A less expensive solution is to stick a long screwdriver through the bolt hole on the wheel, grab the screwdriver in one hand and the wheel in the other, stick the end of the screwdriver into the bolt hole in the hub, and then slide the wheel onto the hub.
My 80s BMWs came with a tool that seemed designed for this purpose, I forget if the Mini comes with something similar.
_________________
<img src="http://my.athenet.net/~mtr/mini/minirowsm.jpg">
<hr>
04 Blk/Blk/Anthraccite MCS
Old May 19, 2004 | 05:47 AM
FraserBonnett's Avatar
FraserBonnett
FYI, I was always told to re-check torque on lug nuts after about 100 miles or so. I found mine do losen up a bit.
Old May 19, 2004 | 06:03 AM
2Cool's Avatar
2Cool
No idea why you would need pins on a Mini wheel, they aren't all that heavy and lug bolts are fairly easy to work with once you do it a few times. Maybe if you have rims that are not hub centric it might be an issue. Maybe its just because I am used to working with BMW and Porsche wheels... they make a Mini rim feel like a feather.
As for torque, it is also good to use a bit of anti-seize on the bolts, as it ensures accurate torque and ease of removal later. Especially if you autocross/race and have the rims off fairly often. I normally use an electric impact to remove, and also to spin them back on, but light on the on part. Then torque to spec with a good torque wrench.
Old May 19, 2004 | 06:13 AM
norm03s's Avatar
norm03s
Good advice and don't forget to anti-seize the hub for easy wheel removal later.
Old May 19, 2004 | 09:40 AM
bradman's Avatar
bradman
FWIW - be careful with using anti-sieze compund on wheel bolts (or any other fastener). Torque specs are based on threads being lightly oiled (emphasis on the lightly). Anti-sieze is very slippery and can lead to fasteners actually being over-torqued by some amount. I usually spray fasteners with a bit of good old WD-40 and thighten them up. If I notice any binding while torquing them, I remove them and put a light layer of motor oil on the threads and try again. That usually works fine. I generally only use antisieze on fasteners that get hot and that are exposed to the elements (e.g., exhaust system nuts and bolts, caliper mounting bolts, etc.).
Old May 19, 2004 | 03:29 PM
rfath's Avatar
rfath
ouch. I'm going to go hug my MINI mechanics!
Had someone overtorque the MINI's bolts after I had them balance the wheel. I called them on it... oh NO, they'd NEVER use the pneumatic tools on ANY WHEEL!
Riiiiight.. that's why it took two people *jumping* on a 6-foot breaker bar to get the bolts back off. These two people weren't small people.
Had the Audi dealership pull the same crap. I think they're just too lazy to walk over and pick up the correct tool. It's no excuse, of course...
Old May 21, 2004 | 01:24 AM
pocketrocketowner
"Riiiiight.. that's why it took two people *jumping* on a 6-foot breaker bar to get the bolts back off. These two people weren't small people."
Maaaaan......some pneumatic tool that one....lets see two people at 150 lbs each0 300 times 6 feet WOW that is 1800 Ft. Pounds of torque......Ah wan't one of them babies.......
Of course, we all know all MINI's get their wheels properly torqued by a little guy in a white lab coat at the factory. His name is Herr Ein and he is an expat from the Fatherland living in England......takes him ten minutes per car and calibrates that there torque wrench every 20 cars, which takes another half hour. Pretty busy guy.....
Old May 21, 2004 | 02:54 AM
holdenontoit's Avatar
holdenontoit
I am a tool maker(read fancy machinist), and yes indeedy that's all this is,and as for $25 2 long bolts of the same thread:MAYBE $2.00,1 hack saw blade:$.89,a little yankee ingenuity and frugality:priceless(you really shouldn't even need the holes and if you feel you do,add :1 drill:$1.59).$25! good grief,no wonder so many people are outsourcing work outside the USA.
UncDeo
Nov 4, 2019 04:08 AM
BRracing
Oct 24, 2015 10:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
broncobuddha
Sep 1, 2015 06:32 PM
