R50/53 Fuel Pump Regulator and Battery Related Issue
Old Jul 5, 2013 | 11:55 AM
noeldesigns's Avatar
noeldesigns
New to Forum. Thanks. Had AAA come out to change a battery. The guy who did it did not install the energy saver underneath the dash before changing the battery.
The battery tech swapped out the battery and then the car doesn't start at all. It cranks but does not start.
Towed to mini dealer and they tell me the fuel pump regulator need replacement.
Is this just a coincidence or could not connecting the energy saver or battery swap out cause some sort of electrical issue.
After the battery swap-out, the battery tech kept stomping on the gas pedal like it was an old carb style.
Any feedback is welcome.
Grant
Old Jul 5, 2013 | 02:42 PM
crazyworld's Avatar
crazyworld
First off, I have to ask.... what is an 'energy saver'?
Second, and more importantly, did your engine crank BEFORE the battery swap? Still have the old battery or AAA took that?
Old Jul 5, 2013 | 03:22 PM
noeldesigns
Energy saver keeps data and is underneath xash. Aaa kept battery. Car started with jumper cables. Battery got changed and then would crank but not start. Dealer says fuel pump regulator burned out
QUOTE=crazyworld;3769365]First off, I have to ask.... what is an 'energy saver'?
Second, and more importantly, did your engine crank BEFORE the battery swap? Still have the old battery or AAA took that?[/QUOTE]
Old Jul 5, 2013 | 03:36 PM
crazyworld's Avatar
crazyworld
I've never heard of the energy saver so I can't speak to that effect. Almost sounds like he may have shorted something out. Do you trust your dealership? Did they give you a price?
Old Jul 5, 2013 | 03:41 PM
crazyworld's Avatar
crazyworld
May want to check all fuses too. How many seconds were you/he cranking on it for? Did mini check the battery and verify the new battery is ok?
Old Jul 5, 2013 | 03:44 PM
noeldesigns
All fuses good. New battery good also. Mini had to crank for 5 minutes to get it started.
Old Jul 5, 2013 | 03:51 PM
crazyworld's Avatar
crazyworld
Well if you need a new regulator you need a new regulator. On the other hand, might you be able to get something back from AAA, possibly. I mean, they guy jumped your car and it started up no problem, then changed your battery and it wouldn't start. I think it's very possible he could have shorted the system. All you have to do is touch that positive terminal once anywhere to the grounded body. Proving it, may be a little more difficult but not unreasonable.
Anyone else want to weigh in on this?
Old Jul 5, 2013 | 03:58 PM
r34king's Avatar
r34king
Fuel pump or fuel pressure regulator. I'm guessing you are talking about the fuel pump. I have yet to see one go bad from swapping a battery in a r50/53. Impossible - no. Unlikely to be related. How many miles on car, how many years did it sit with fuel in the tank, how often do you let the fuel light come on. All those are more likely to kill the pump, especially the last one. Fuel In the tank is a "coolant" for the fuel pump. Low fuel and the pum p isbt beibg cooled, overheating the pump and eventually killing it.
Old Jul 5, 2013 | 05:51 PM
noeldesigns
Thanks for replies. 81,000 miles on car. Serviced per manual. Tank does not go below 1/4 tank and always filled up when refueling. It is the fuel pump that went. Just too coincidental. I did not watch the battery tech replace the battery although I did see the new battery go in. So, not sure if he touched the positive and caused a short.
09R56
Nov 16, 2022 10:49 AM
scottrn
Aug 22, 2015 07:26 PM
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
Dsinkster
Aug 17, 2015 03:24 PM
kpl
Aug 11, 2015 04:52 AM
