R50/53 Need advice for tune
Old May 13, 2013 | 03:04 PM
R53minime's Avatar
R53minime
I recently installed a 17% pulley and dt bpv and at 2500 to about 3500 rpm's if I go wot it wants to stutter pretty bad does anyone know we're I can get it tuned near Dayton Ohio or have any suggestions to what might be causing it?
Old May 13, 2013 | 03:12 PM
GreekDrifter91's Avatar
GreekDrifter91
you should not need a tune with a 17%, something else is up is that the only mod you have?
Old May 13, 2013 | 03:14 PM
R53minime's Avatar
R53minime
Ya
Old May 13, 2013 | 03:28 PM
GreekDrifter91
try resetting the ecu https://www.northamericanmotoring.co...nce-guide.html
by the way any lights(codes)?
Old May 13, 2013 | 03:37 PM
R53minime's Avatar
R53minime
I already did that and nope no codes
Old May 13, 2013 | 04:05 PM
GreekDrifter91
did you change your plugs to either jcw or a step colder of what you have? other wise you have a fuel issue which is weird, never heard of this happening though. i do believe though that a CAI is necessary for a 17% but dont quote me on that just yet need to do a little more research. try some fuel injector cleaner stuff. fuel should not be breaking up like how your saying, it does not do it after 3500?
Old May 13, 2013 | 04:08 PM
R53minime's Avatar
R53minime
I do have one step colder plugs and I'm sorry I do have a alta cai I just pulled my plug wire if number 3 on the coil pack and it was pretty corroded I wire brushed it I will see if it fixes it until I get a new coil pack
Old May 13, 2013 | 05:03 PM
GreekDrifter91
yea im done with ideas. maybe someone with more mini knowledge than me can step in.
Old May 13, 2013 | 09:05 PM
ZippyNH's Avatar
ZippyNH
Naww...CAI is not needed...help to get a bit more bang for the $$, but mostly sound....
Cooler plugs....the short of it is it help to lower temps a bit, prevent ping....on a tuned car it allows the tuner to do a few more changes to make more power...on an untuned car, MIGHT still be worth it.....
Since it is recomened plugs be changed every "service" on a JCW, which has a pulley, I think doing it on a S with a pulley is good too!! So new plugs every 30,000..means you are likely overdue..they last MUCH longer on a stock S, but are not pushed as hard.cause they have no pulley...once you add a pulley...the plugs are working harder than on a JCW....IMO get NGK's.
What are you using for fuel?! Octane is EVEN MORE important with a pulley.
Add a bottle of Techron (Mini sells it as MINI branded cleaner) to your fuel tank...see if it helps in a few hundred miles....
As for corrosion on the coil....scotch-brite it...and add a bit of dielectic grease..be sure to clean the wire side of the plug....the dielectric grease will help seal out moisture and prevent future corrosion.
And you DO WANT this issue fixed BEFORE a tune.....
Old May 14, 2013 | 03:27 AM
R53minime's Avatar
R53minime
I always use 93 octane gas I will throw in a bottle of tectron and see what it does
Old May 14, 2013 | 04:37 AM
BlwnAway's Avatar
BlwnAway
How soon after the swap did this start happening?
Old May 14, 2013 | 05:37 AM
Braminator's Avatar
Braminator
Get NGK -4285.plugs
Old May 14, 2013 | 05:39 AM
R53minime's Avatar
R53minime
I put the Ngk plugs in when I did the pulley and it started right away
Old May 14, 2013 | 07:00 AM
BlwnAway's Avatar
BlwnAway
First thing I would do is go to a dealer or euro car specialty shop or maybe even find someone locally with the Bytetronik software, basiclly I would start by clearing your adaptations from the ECU (the above reset doesn't) that way the ECU is learning your new setup & writing adaptations from scratch instead of having to make adjustments from perameters that have probably been set in there for a long time.
And even if this doesn't work, you have eliminated one more possible cause.
Old May 14, 2013 | 08:39 AM
R53minime's Avatar
R53minime
Is bytectronic the software that mini uses?
Old May 14, 2013 | 08:52 AM
BlwnAway's Avatar
BlwnAway
No Bytetronik is aftermarket tuning software, the only reason I mention it is that anyone with the Bytetronik software can clear adaptations from any 1st gen car, not just their own.
Call around, anyone that works on BMW's should be able to do it, last time I had to do it (before my Bytetronik) the shop I went to just did it for nothing, it's basicly just plug it in & push a button.
Old May 14, 2013 | 10:19 AM
ZippyNH's Avatar
ZippyNH
I think driving a few miles will do the same thing thing as clearing the adaptations....
Quick question....have you looked at the connections on the DT bypass valve...just to be sure everything is tight. Same for the IC boots.
Old May 14, 2013 | 12:00 PM
R53minime's Avatar
R53minime
No I have not i will check those as well
kevinlhr310
Aug 27, 2015 06:45 PM
Aug 27, 2015 12:25 PM
Aug 12, 2015 01:24 PM
M7Speed
Vendor Group Buys
Aug 10, 2015 12:32 PM
